whats the point of checking output voltage? what am i looking for?
Just making sure the amp is putting out power.
Do the same for the RCAs going into the amp - negative probe on the sheath, positive on the pin in the middle.
Post back your numbers on each.
Just FYI the DD-1 cant do amps over 15,000 watts at 1 ohm. Not saying I know anything about either of those amps or how much power they do but just letting you know. Apparently there have been issues with large amps (over 15000) causing problems on the DD-1
Had that issue with one of my amps. It takes a TON of power to fry the DD-1 and neither of the amps listed are capable of doing it unless OP hooked the negative clip to a speaker terminal or something.
The dd-1 would make a chirping sound if that was the case.
Edited by SnowDrifter
no i didnt do that its grounded in the proper place ill get those numbers tomorrow after work thanks for the help guys i appreciate it
Ah yes I remember reading about the chirping noise now that you mention it.
try turning your subsonic and filter the other way.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I've noticed on one amp that I had to turn the unit off and back on while hooked up to the amp. Seamed to reset the issue and get a good read from then on out.
tried it when subsonic goes up it stops detecting signal
tried this too still isnt working
so everyone else knows kingsuv scoped my amp a while back so i figured i would try the dd-1 in my truck just to see if it was a coincedence it wasnt working in these two vehicles but it isnt working on my truck either...im out of ideas
Why has track 7 not been mentioned? Try track 7
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
id email tony now. see what he can do for you. him or juan will get it straight.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
