2010 Mustang GT Walled; It Was Fun, Time to go Fast
Run some 8g leads from my amps at the fresno show ill get you a 54... with about 8k per sub:-)... if ya need some 7/8 or bigger allthread I can get it pretty cheap its what I used an stopped all my flex
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Hhhheeeeeeeyyyyyyy man
Iiiiiiiittttttssss totally the bracing
did u know?
I kid I kid.... hit up ray on that allthread! Beatmode then 1 or 2 per side, maybe get some plate and drill 3 holes in it couple for screws one for the bolt in the middle (think 1/4" thick 2 or 3 " x 10 and put on the top bottom on the inside like a huge washer to increase the area its holding)
But wall looks good I like it man glad u like the mayhems now get another 7.5k :) u know u want too
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
So, I took out the subs and checked for an damage to the current bracing. The vertical 1" dowels going floor to port and horizontal going baffle to back wall are holding solid. However, the dowel between the side walls broke free, which explains why the sides were breathing. I would love to use that big ass allthread, but there is no way to get it in at this point. So i'll use steel, either rod or square tubing, to bring the side walls together. Also adding a few angle brackets inside where the port meets the baffle, which will be tricky since I have to open them up by 15 degrees.
What are some good places to find steel for bracing? Home Depot and Lowes are pretty limited.
SMD Super Seller
My Feedback Thread
Gotta go to some local supply shop or something. I'm like 3,000 miles away, so I can't recommend shit lol.
Too bad you can't use all thread, if you could find a way to get some in there, use some sort of turnbuckle setup to pull the sides towards each other and keep a constant pressure on them.... Don't know if I'm making any sense to you or not lol, the theory in my head seems legit
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
They make all-thread couplings. Get two pieces of all-thread that are about an inch shorter than the actual distance needed for one whole piece and use the coupling to bring them together.
SMD Super Seller/Buyer
Audison----Hertz----Rainbow
