I got suckered into building a box and now the right sub is clicking. Please help
MrFree
This is how it got so screwed up.
After I found out that I put the dimensions in for a round and slot port I fixed it and it came to 30 something Hz etc,,, Im going to cry myself to sleep now thank you for all that responded
Edit: No that really dont show anything except that on top of building a box to big I had a hard time doing it too.uhm?
R.I.P...99'Dodge Grand Caravan
03 Lancer Oz
Big 3
HU-JVC KD-530
RCA's-rockerfosgate
41/2 inch Infinity mids
Subs-(12's)2 Orion xtr124
Amp-Coustic600se
battery-2 x stock, 1x Shuriken SK-BT20
Box-L-ported 3.562cubes@35Hz
miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive)
I dont have flex yet but damn I sound good,(coming soon....flex)
Check out my HHR install
Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/
Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
.6 woofer displacement.. ok.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
sooooo confused on the port
R.I.P!
(Nov-29-2009)
92 explorer
current build
holy low frequency...
my RE XXX box was tuned even higher than that.
and the XXX is BUILT for the low frequencies and to stay loud while doing it.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Psshh
31hz is on the high side for me :P
I'm a mid 20s kinda guy
i told you in your last thread before you even made the box, that what you're showing right there, you told the calc that you're using both a slot port and a circle port.
edit: you should probably hit F1 and read the instructions
Psshh
:o
holy mexican jesus..
then again my box for it was still too small for true optimum peak (@ 3.9cubes before displacement?!?!?)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Psshh
x2
damn that sucks that you fucked up.
id start off by telling the kid you have a better box design and you messed up on the old one.
hopefully not too much damage was done to the subs. check the subs then build the box right and if the noise goes away then you should be good.
and btw unless you scope the HU DO NOT EVER GO MAX VOLUME! set gains like 5-10 clicks before max. your much less likely to have clipping at that volume.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
hate to be a dick, but you need to learn how to design a box before building it.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
try these numbers in torres calc to see if thats closer to DD's specs has to sound better than what you already built
sub up...port back
box dims...16h..37w..24d
port dims...14.5h..5w...19L
.6 sub displacement
3 common port walls
37.11hz....4.97net volume...14.59port per cubic foot
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
  • Who's Online   0 Members, 0 Anonymous, 877 Guests (See full list)
