uhoh_45 Posted April 4, 2012 Report Posted April 4, 2012 45's do not always add db threaded rod is a good strong more expensive support to having wood supports Were can you purchase these rods from, and I no I see most people running them through the top of there box, but wat about the bottom, wat goes on the bottom , meaning the floor??? Reason I'm asking because the box wouldn't sit level with the floor rite. in my wall build i braced from bottom to top and front to back i used 3/16" plate on bottom with some nuts welded to it and then counter sunk the 3/16" plate into the wood to make it level more found here R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Basson50 Posted April 4, 2012 Author Report Posted April 4, 2012 45's do not always add db threaded rod is a good strong more expensive support to having wood supports Were can you purchase these rods from, and I no I see most people running them through the top of there box, but wat about the bottom, wat goes on the bottom , meaning the floor??? Reason I'm asking because the box wouldn't sit level with the floor rite. in my wall build i braced from bottom to top and front to back Man that looks like a solid build i used 3/16" plate on bottom with some nuts welded to it and then counter sunk the 3/16" plate into the wood to make it level more found here
Basson50 Posted April 4, 2012 Author Report Posted April 4, 2012 45's do not always add db threaded rod is a good strong more expensive support to having wood supports Were can you purchase these rods from, and I no I see most people running them through the top of there box, but wat about the bottom, wat goes on the bottom , meaning the floor??? Reason I'm asking because the box wouldn't sit level with the floor rite. in my wall build i braced from bottom to top and front to back i used 3/16" plate on bottom with some nuts welded to it and then counter sunk the 3/16" plate into the wood to make it level more found here Oh ok I see wat you mean when you say you used a plate and welded it.
BassJunkie Posted April 4, 2012 Report Posted April 4, 2012 45's are sometimes worthless. They're better for box bracing than directing air imo. There have been tests done to show a loss with some 45s but thats probably due to a loss in airspace. Yes, threaded steel rod will be stronger than wood bracing if used correctly. Were can you purchase these rods from, and I no I see most people running them through the top of there box, but wat about the bottom, wat goes on the bottom , meaning the floor??? Reason I'm asking because the box wouldn't sit level with the floor rite. They're in the bolt section of lowes. You could always put wood around them to make the box taller so the allthread wouldn't make the box sit crooked, as well as counter sink the bolt. Many ways around this issue. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
Basson50 Posted April 4, 2012 Author Report Posted April 4, 2012 Wats the best size rods to use, I'm doing. Box for three niteshade 15"s, with two 8 inch aero ports.
BassJunkie Posted April 4, 2012 Report Posted April 4, 2012 I use 3/4" personally, if you can find/afford bigger then go bigger. Bigger rod means more expensive nuts/washers though too. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
uhoh_45 Posted April 4, 2012 Report Posted April 4, 2012 I use 3/4" personally, if you can find/afford bigger then go bigger. Bigger rod means more expensive nuts/washers though too. holy shit 3/4" that is some thick all thread haha R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
kingsuv Posted April 4, 2012 Report Posted April 4, 2012 3/4 is the smallest I will go. I have had issues with smaller rod resonating Also if you build your box correctly, you won't need 45's for added strength. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
Basson50 Posted April 4, 2012 Author Report Posted April 4, 2012 3/4 is the smallest I will go. I have had issues with smaller rod resonating Also if you build your box correctly, you won't need 45's for added strength. I see eveybody always says if the box is built correctly , but wat makes boxes so different .... I see you build boxes, if you were to build a box for three niteshade 15"s in a 10 cube box after displacements with two 8 inch aero ports tuned to 33.
uhoh_45 Posted April 4, 2012 Report Posted April 4, 2012 3/4 is the smallest I will go. I have had issues with smaller rod resonating Also if you build your box correctly, you won't need 45's for added strength. come to think of it i've ran into that problem with 3/8" i thought my 5/8" rod was over kill haha R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
