OK so I just got my system in my s10 Friday night. Monday on the way home from work I had my system about half my normal listening volume. All of sudden it was quite, figured it was a fuse. I get home checked my 300 under the Hood and the 3 45s at the amp and they all look good.
Ground is to straight frame and clean as a whistle
Pulled the amp cover thinking it was something inside and I find nothing looking abnormal
Any ideas on what it could be let me know
Amp is a Re xt4000D
Did it go into protect mode ??
take out wires in amp reput them back in if the light has ever flicked its probably your ground just wiggle your cable around thats connected to the chassis see if the light flickers another thing is check the remote turn on
Yea it went into protect, I turned off the truck when I got home. Left for the store, it played another couple minutes and now it just goes into protect as soon as the ignition comes on.
I pulled the speaker wire thinking it might have been a impedance issue, Still no luck.
Yea I'm not sure, I'm pretty stumped.
tuned in.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Its protecting because of low voltage or load more than likely. if it comes out thats a good thing. What are you running with it and what load.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It's a older double slug SSD 12 wired to 1 ohm
Ill put my meter on it and see what the voltage is at the amp when I get home, I'll also test the load on the sub just to eliminate it.
