Metal box???
Metal will resonate. It would be very rigid but it may not be easy to kill the resonation
This^^ the box will probably ring every time the subs move. And how thick is the steel plate?
Couple sheets of sound deadener?
i forgot where i had seen it but it was in a panda or marbella they did steel no wall setup and were using 1"+thick plate for everything
edit- fuck it was murillo from soundigital
this was the plate he was using (his photo)
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Those cars are not playing musivc though
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
ive had a customer ask me about metal boxes. i told him he could try to make a box out of MDF and cover it in thin aluminum for the look he was going for
I won't truly make it soon if ever. I was just wondering if u could make it happen our not. But the plate we have at school is 3/8" & 1/4" and whoever said do sound dreamer thats what I'm thinking ud have to do. Can't think of a diff way to stop the resonation.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Internal sheet braces would help. basically some flat iron on edge welded to the sheet in X pattern... along with threaded rod. It can be done in other words, but you wont have any weight savings over mdf/plywood and the bracing is going to hurt internal airflow against the sides of the box.
I think you'd have better luck making a carbon fiber box.
Hammerdown... 1%
seen it in a mag before looks cool but i don't know bout the sound
REFF'S
My link
EBAY
  • Who's Online   2 Members, 0 Anonymous, 1913 Guests (See full list)
