They are 1 ohm stable, I am sure if you have the electrical to handle it you can try it out but I would not suggest running it at .5 ohm saily if you have to ask.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Why would you run it at 0.5 ohms? that amp was designed to put out 2500 watts @1,2 and 4 ohms.
That too, also if you want more power, dish up a bit more for the bdCP and that thing will do 3200 give or take a bit at 1 ohm and rated at 2 ohms.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Blowing rockford amps aren't cheap to fix and will cost quite a bit to repair, why people have a fetish running below rated ohm loads is taking a chance on blowing subs and amps for no reason other than being to damn cheap to buy another amp.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
get the bdCP version and run at 2 ohms instead of .5 which you should never do with a 1 ohm stable amp.
Edited by ChevyBoy95
I want to run 2 Mayhem 12 D1 –Ascendant Audio 12 on two Rockford fosgate t2500-1bd but I only have one amp rite now till I get another rft2500-1bd
2 D1 will go down to 1 ohm or 4 ohm on a single amp
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Depending on box and imp rise, you might sneak above 1 ohm. Fosgate amps will go into protect with .5 load. Why do people want people want to run .5 ohm these days.?!?!!?
The amp will be ran at .35 ohms because the subs in the other thread are dual 2ohm mayhems, which are not really dual 2 ohm coils, they are dual 1.4ohms, which brings it down to .35 ohms.
Those amps do not like to run much lower than .7ish ohms, or they like to go snap crackle pop.
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
