There is absolutely not one need in any possible way at all even a little bit to use 0g on that amp. If, and ONLY if you still feel a need to run 1/0 to it. You still put a 60 amp anl fuse 6" from the battery and if you don't trust the fuses on the amp 6" from the amp as well.
Why would you put a fuse on the power wire 6 inches from the amp if the amp has on board fusing? It is completely pointless.
I've learned from US Amps that you can't always trust the onboard fusing.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
run the 1/0 to a distribution block and then a small run of 4ga from there to the amp. Problem solved.
Follow my Tweet (Twitter)
COMPLETELY pointless. Put a fuse next to the battery and call it a day.
Wow Steve! Im honored u posted! So when I want to upgrade, just take out the distro? Because I DONT plan to keep these amps or sub stage. Just wanted to atleast start from somewhere, learn as I go and upgrade in the future but without the hassle of pulling wire back out!
Once the wedding and honeymoon are done I can mess around a little bit more. Im looking into DC or Sundown!
