Crazy thoughts.. Would this be practical? Would be sweet though
Couple of ideas that I have had in my head and thought I should throw them on the table before I forget.
1. When it comes to making connection from the leads of the sub-woofer to the basket terminals.
Would it not be cool to have a lead with a magnetic tip on it so if you were re coning a sub-woofer you don't have to solder the connection just a quick connect with a magnet and your done. May not be practical in your every day sub-woofer but for competition grade woofers when you have to re cone in the field this would be great.
2. Bluetooth
Would it be practical to create a Bluetooth device that you could plug right into the back of your head unit and send the signal wireless to a Bluetooth device on the amp. With it being a digital signal there would be no noise in it you would just need a digital to analog converter Bluetooth device on the amp end.
Edited by Hotdog
Both ideas sound great to me, but I am no engineer and have no clue if it's pratical and will even work.? But none the less good ideas.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
The blue tooth idea would be flipping sweet... No longer have to think about where to run wires in comparison to power wires... And possibly better quality of signal
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
The bluetooth might work well. Create a device that you plug your front/rear/sub into, and it bluetooths it to another device that you place in the back, which runs 3 short RCA's to the amps.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
If any of you have interesting Idea's put them out there.
Just imagine running the lead of the sub woofer through the hole on this magnet then all you would have to do is put it right on the terminal plate. Would be plenty strong enough to hold. of course it would come from the factory with the center hole filled with solder so the lead is secure.
f679am-20mm-dia-x-20mm-thick-n42-neodymium-x-6mm-hole-magnet-13kg-pull-x1-f10-o--1681-p.jpg
Edited by Hotdog
The only thing you would require for this to work would be power ground and remote which you could wire right into the amps connections. Same on the radio end that way there is signal at both ends when radio is on.
With direct leads no need to worry about solder. :)
But 9 times out of 10 subs dont have direct leads and your idea sounds like a nifty one for competitors that dont have time to solder.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
I would not want to have magnets except the motor of the speaker itself. Having direct connect leads works fine for me, and if one need it they can easily be extended.
Bluetooth idea is badass! i hope to see that soon lol
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Its good you are thinking of ideas.
The main drawbacks are these.
Magnetic woofer connections - Not a solid connection, current and voltage transfer capabilities would be on the low end. Susceptible to vibration and high power may induce arcing at connection which would create heat at connector.
Bluetooth amp signal input. - Bluetooth is basically a radio transmitter and receiver. Because of this, interference from outside sources is possible, signal to noise ratio is diminished from standard hard lines, signal voltage is limited, and frequency response is limited.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 1220 Guests (See full list)
