i just ran the big 3 and installed a XS Power D 3100 in my 2000 camry today and my voltage is only getting up to about 13.9 - 14.0V... before i ran the big 3 and installed the batt it was getting up to around 14.4 - 14.5V... any thoughts?
BOOSH!
probably need a new alternator, i did that with mine and i gained a little with stock alt, or maybe a bad connection somewhere, did you crimp or solder your cables?
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
big three doesn't increase the amount of power you get, it only increases the way of transporting it.
think of your power like a cup of water.
stock electrical is like drinking through a coffee stir straw
and after a big 3 upgrade its like drinking through a mcdonalds straw.
your going to need a new alternator to increase the amount of power your putting out
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Recheck your grounds, normally you won't see an increase in voltage it's an increase in steady amperage. I've never seen a decrease in voltage from it though so if you can post some pics of all your wiring and connections maybe we can diagnose from those.
ill have to check all my connections... i kinda doubt its bad crimps tho. all the wire that i used came out of my astro (which just died on me) but it didnt have any voltage issues. it was doing a 149.3 on music. i understand that i wont see a voltage gain and i also understand that the big 3 only allows more amperage to flow. what i cant figure out is why after running the big 3 ive lost almost half a volt.
BOOSH!
also im looking into an alt for my camry... ive got a 300a excessive amperage alt in the astro and i guess i was pleased... i had belt slipping issues in the beginning but got em resolved... any suggestions for a 200+ amp alt for the camry?
BOOSH!
Did you clean your ground point down to metal ? Are you using 1/0 for the big three ? When was the last time your battery was topped off (is it brand new or used)?
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
yeah i ground down to bare metal and the xs d 3100 is new and topped off, the under the hood batt is old and could be replaced... i just added new wires and left the existing factory wires as well. i think im gonna start with getting a new batt under the hood and see what happens from there.
BOOSH!
  • Who's Online   0 Members, 0 Anonymous, 586 Guests (See full list)
