Power Wire From Battery MELTED Into
I will sand the paint down. I will be installing my two older type R's at 1000 RMS. Will I need bigger wire? I will have to replace the wire anyways because it melted, but do I need to get a bigger gauge?
that ground doesn't look very good imo , and then with how cars are made with uni-body construction it could actually be a worse ground than it looks , body and structure parts being glued and spot welded . shock tower has been my first choice for grounding or seat mount bolts sometimes
Sand your grounding point down to bare metal and secure the ground to the chassis using a nut and bolt.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
even though its over kill use 0 awg wire and you will have the wire ran for any up grades later on ....
and that ground is a joke did a car audio place install with 2 self tapers ... if so take it back and show the owner .. the owner might not know the installer doesnt have a clue on how to do the grounds correctly
  • Who's Online   0 Members, 0 Anonymous, 2077 Guests (See full list)
