Ported Box Feedback
well 1" for the plexiglass back, wouldnt require any extra work just instead of placing a 3/4"mdf board on the back side of the box you use 1" plexi. no router needed to screw and glue a peice of plexi to a box.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I played around with it more and here is what I came up with:
The new models:
Then I added some color.
Imagine it being a SKAR sub rather than the JL, it was all I could find in the sketchup warehouse.
Through the window:
Then painted:
Lemme know what you you guys think and if this will work okay!
Only in the phone at moment so can't run and numbers
But bring the box back to 19.75 so the overall dia. Is 26.5" to lift the net if the box
That should bring the port down to low 15sq" per/ft
Also try to off set the sub away from port opening,
Another thing with the way I filled out Torres you can put down 1 for baffle and not have to work out the volume
But you do have to add on volume for the plexiglas resess
Once you cal. That up and the bracing if need be you can put a minus number in bracing area if required
I already had the displacement of the bracing and baffle subtracted as well as the cutout for the plexi added in that last calculation. I wasn't sure how the calculator would handle the 2nd baffle as it doesn't go all the way across the box so i just took care of it myself.
Adding the extra half inch brings the tuning down to 33.18 Hz and the port to 15.25 in^2 per foot.
By off setting the sub do you mean moving it as close to the non-port wall as possible?
move it over 1-2" and it should be good. although i dont see much point in moving it over. if you want the window to see the sub then moving it over will just hide more of the sub from being veiwed. unless you also more the window over to match the subs location.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
