What's a good voltage?
On a standard system, what's a general rule of thumb on a good voltage? not in a perfect world but realistic one. What should be an epected drop thats safe and such. . . . Whats your systen electrical like and voltage???
I have a stock alt/batt and big 3 done in 1awg OFC. I rest idle around 14.2-14.6 depending on the heat of the day. And I can drop to no less than 12.5. getting below that you should be careful, because dipping past 12 is bad.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Indeed..this is why i preach getting an external volt meter..once you start dropping into the low 12's MAYBE high 11's..time to back off the volume knob and let everything charge back up for a bit
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Yup, I tested my car sitting at idle and wanging on it, barely ever touched under 12.5. So I think I am fine for now without a volt meter. WIll need it though once I get my new sub and everything DD-1'd.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I rest at 13.6 fully warmed up. But only drop to 13 full tilt. Aq3500.1
270 amp alt.
2 xs power xp3000's.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
I have stock alt, big 3, and a d1200 under the hood and only drop to 13.8 full tilt at idle but that's only with 1500 watts but I'm very happy with it
Edit: And I charge at 14.2 so only dropping .4v
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
I guess a better question would be, what's a safe voltage drop, lol. :unknw:
220 amp mechman alt
DC 2k @ 1ohm
d1200 & XP3000
1 run of + and - 1/0 gauge
I drop .1 volts at full tilt on a hot day, but I rest at around 14.1~.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
At or above your batteries float voltage, preferably at your alternators set point voltage. Turn your car off and put a DMM to your batt posts, keep that number in mind and see if you stay above it.
I'm gonna hate
just measured mine right now, fully warmed up, charging @ 14.38
1 x Wolfram W-4500.1
2 x XS Power D5100's
250A Singer Alternator
2.67 Cubes @ 29hz
  • Who's Online   0 Members, 0 Anonymous, 1391 Guests (See full list)
