Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
Looks good. Where are you buying your vynil wrap from? Btw. I should be sending some money your way here in a couple of Mins.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
My walmart sells vinyl. Idk if urs does. Might wanna look into it cause yourautotrims shipping is so expensive. I did my headliner with their suede.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Finally got a little bit done today. Finished stripping the old speaker wire from the doors, it was a PITA to pull through the grommet. Ran brand new RCA's. And I pre-drilled my baffle mounting-bolt holes, and wrapped half of the baffle. This was the hardest piece i've ever done. Probably should have used a heat gun or blowdryer LOL.
On the performance end, I am still waiting for the shop schedule to match up with mine. The only days I can leave it are Tuesday morning through Wednesday evening. It will happen hopefully sooner than later.
SMD Super Seller
My Feedback Thread
I knew about cutting. I've had to use my Dremel and cut away most of what I could. That level 6 was doin some work btw! I need to get around to mine once its out of the shop. Really like how the baffle is turnin out too.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I couldn't wrap like that. Not even close, and you made it look perfect!
I like the way IB setups look. Just a clean baffle with a sub in it, and no box taking up space in the trunk.
SnowDrifter approves
