why? it would just sit there,... idle....
turn on, and sit,....... no signal coming in... to me, its just on, sitting there,...... like, if you had a set up... and had your HU off.........??? am i missing something?
exactly what im thinking. no rca's = no input = no output on that channel = no draw. using 2 channels out of 4 makes half the amp work (and thus using half the current), no?
edit: i dont see why that channel would still work, since every channel receives a separate signal
Edited by Kranny
Would it be easier to just have a switch on the remote of the 4 channel to turn it off and on? Oh unless a 4 channel is all you are running. Didnt read that at first.
Edited by bassface
wow weird.... hell,.. what do you think fading does???? takes away from front/rear......
Ill even be more fucked up and or wrong here.....
RCA sig (TO ME) are last to go in, on any install,... first OUT on Trouble shooting........
Ive added an amp, and no signal, and cruised around like that for days... weeks...months....
Man,... if my head is somewhere wrong on this... please fill me in....
Think about what is going on in a amp ... its ALWAYS making amplication of signal ... Thats why you hear people on this forum say that you do not use your gain control knob as a volume control ... its job is to make power
Would you run a washing machine with no water ?? same principle ...
But bro,... No signal,... Im not even turning the washing machine on???
as long as there is load on those channels you should be fine
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
take the 12v on, and remote, and put em to your battery,.add a ground of course........ the amp WILL turn on..... and be "pulling" damn near nothing....like, enough amps to turn the ON led on....no more.... there is no signal to make it draw.....fuck.. maybe i dont understand the question??????. Im not trying to argue my friend..... and again... maybe i dont understand the question. And in now way trying to be a dick
Try it ... See what happens ...
