Ok, I have two sundown e12s and I have set the amp with dd1 on track 5, and its running on eockfird t-1500 at 2ohms, amp puts out 1800@2.
Now I know I have over 2x rms on the subs but I know im running a clean signal, but only one sub is getting warm and other is not.
Its mot a super warm but its after about 30 sec of playing and you get that glue smell... my guess is that maybe a back connection on the push terminals, I am guilty of putting 2 10ga wires crammed into the terminals, just hoping for a second opinion or other suggestions. THANKS!
Which one is closer to the port? Loading issue maybe so the one that unloads is moving more air around the coil keeping it cooler maybe?
2007 Pacifica
Bolts through the box wires coils series and subs parellel.
Aeroports in center so no port loading
That is definetly weird. You should be really careful with that power to those subs, they are only 300W RMS, your feeding 3x the power they are rated for. Did you build the box smaller than what is recommended for the subs?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Subs are 400rms but yes that is alit of power but I would think if its due to over powering both would get hot not just one? Regardless when I get back from Oklahoma I will be taking out the subs and wiring in banana plugs for the push terminals.
The box is made in spec for sa12s just got the e12s at a cheap price so I ran with them for the time being.
chek your ohm reading on the coils (individual) just to see if there is any variation
swap the subs in the box and see if the same one gets warm
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
