Just wondering if anybody has heard both sealed or ported and how does it sound sealed? Do you loose any Bass when sealed or does it go deeper?
Most people i see run dual subs on ported just wondering if any runs them on sealed and if you have heard them on ported
What are you looking for? To sound good but not loud sealed for output ported
Sealed can go low its all in the tunning how do you tune a sealed box you may ask by its size
For the most part you get way more output from a ported box but does not sound as well or controlled as a sealed box for the most part
In the exact same enviornment, ported will be louder than sealed.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Designed correctly, a ported box will sound better than a sealed box, but a sealed box is very easy to design.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have a ported box right now for dual VVX 15, I dont push it to the max (only time was when metered) I was thinking if i put them on 2 separate sealed box recommended specs 1.75 to 2.5, I'm thinking about clost to 2.5 per sub, and doing i regain more truck space, i can stack them on top of each other if needed, or i can take one of them out if space is really needed.
Im also thinking that the box will be manageable since im moving 1 sub at a time this dual sub box weighs a ton.
So i want to know how much will i loose, right now I average 143db metered. that's why i was asking if anybody have a dual VVX on a sealed box and it will be great if they can post metered score if any.
I love sealed, but then again, I don't compete, and was limited space. If you lived closer, I would show you. They do quite well sealed. I'll try to get a better video later with the HD camera. Honestly, with the space you have, I'd stay ported. You can do two separate boxes, with aero ports. I guess my point is, if you are going to be close to whats recommended for ported, then why not port?
10501650_10203332501847103_1859383749711
Blown
if I go sealed on 2.5 cu ft per box I'm gaining 12 inches on length, 4 inches on depth and raise the height 1 inch which i dont mind. if i go 2.0 cu ft box size per sub will be like 18x11x18 LXWXH
Right now my box is 44W x 17H x 19D= 2.76 cu.ft. per chamber
Recommended is 2.2-2. something ported, so you can go 2.2 and ported. Unless you 1.5-1.75 sealed, you aren't gonna gain much space.You can always build it taller?
Blown
Play with build the sealed box like you want but I would hang on to the ported one something tells me after a day or 2 you will reinstall the ported box
how much power do you have? Im doing 45 on 2 vvx 12s in a trunk
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
