Running Wires Straight Through the Box.
So, I've scrapped the whole bolt terminal idea..
My Sub & new Batt is going to be here within an hour or two.
I'm just going to run my wires straight through the box, gonna drill a whole..
So, what should I use to seal it up?
Fiberglass resin is probably out of the question as I don't think I have that in my garage & I'm pretty much out of money.
I do however think I've seen some wood glue, but idk how well that will hold up, or even seal off the hole if that.
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
get some MDF dust and mix it with wood glue.
becomes an "at-home" filler
Edited by Robby Holmes
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Silicone
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Caulking will do fine.
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
i've found that liquid spray on rubber works pretty easy. it's like 10 bucks a can at wal mart. just don't drill too big of a hole
More box builds
I'm with captain stupid.
make the hole small and force the wire through, if you cant get the wire through use the same bit and run it through the whole one more time then try agian. get the hole just big enough to where the wire will barely force through it and then use some caulkin, silicone, or the rubber spray.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Silicone, hot glue, tape, really anything. It's not a structural part of the box, and it's not a huge gap to fill.
When you drill the holes, drill them JUST large enough to run the wire through. You should have to push a bit, so the wire is 'pressure fitted' in the hole.
  • Hot Glue
  • Silicone
  • Caulking
  • Snot mixed with flour
  • etc etc
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2142 Guests (See full list)
