Didn't really know what section to put this in so I figured I would throw it in here.
So I am working on my first build and just got my amp, an Audison LRx 4.300.
It has 4 gauge inputs and I was wondering if you guys had any tricks on how to get as many strands as possible into the input terminal?
Thanks for any replies in advance!
Edited by mttornquist
Just twist them up real tight. Make sure the strands are all cut the same length. If you still have problems throw the wire in the freezer for a couple hours it will shrink and then it should fit. You can also get lugs that just have a round pole piece that you can solder your wire into and then put that in the terminal.
What ever wire size you have, cut away about an inch and a half of your shielding. Twist as tightly as you can, apply a bunch of flux onto the exposed wire then smother the wire in solder. After you get a solid wire take it to a grinder and grind it down to the exact size you need.
Edit: then you don't need gauge adapters just some solder
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
SkittlesRgood has a method of getting most of the strands in a ring terminal. It involves using a paperclip iirc. He mentioned it like a year and a half- two ago.. back when I was new.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Thanks!
I will keep this as a plan B incase the next option doesn't work.
Searched around the forum more and seem to have found what you are talking about:
http://www.stevemeadedesigns.com/board/topic/85229-how-to-get-every-last-strand-of-wire-in-that-terminal/page__p__1167696__hl__+skittlesrgood%20+wire%20+strands%20+terminal__fromsearch__1#entry1167696
Looks like it should work and I will try it. Thanks!!
I just work them in with my fingers. I dont try to insert the whole thing right away, i put the tip partially in (just a tease for the amp) and than i start working my fingers around the tip stuffing the little strands in before thrusting the wire all the way deep inside.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
some of you guys really overcomplicate things.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
