Im about to install 2 kinetik hc-2400's in the back of my s10 (inside the jumpseat compartment if they fit) they will be stacked and linked with 1/0 knu koncepts wire. I'm not sure if I should do my 0/1 gauge run to them from the alternator directly or from the front battery. I'll be running the stock alternator and stock type battery in the front until I figure out exactly what alt and what size battery I can fit in the front. I'm running a kicker zx1500.1 powering a single dc level 5 18" sub off stock everything with only big 3 done and I have pretty bad voltage drops. I've also been looking at everyones opinion on battery isolators and seems I don't need one. But I'd like to know for sure. So any help on how I should wire these batts in would be great.
2004 Nissan 350z slammed on topspeed coilovers
pioneer appradio
B2 audio Quota for sub
B2 audio HN15 sub
Lunar L2200 for highs
Infinity kappa 60.9 components in doors
Under construction still.
Yea I know that. But for a week or 2 it will be fine until I figure out what battery I can get up front. And I'll have a battery tender plugged in at all times when parked to keep everything topped off
pioneer appradio
B2 audio HN15 sub
/\ that's pretty much what 2 hc-2400's is going to look like in my little truck lol
pioneer appradio
B2 audio HN15 sub
You can get an xs d3400 in the stock battery spot with minor modification to the battery tray.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
from front battery, and get an agm up front bc itll destroy your kinetics over time
it wont destroy them, i have ran kinetiks with stock batteries for months and they still rest 12.9v.
yes it is bad for them, but destroy is a strong word.
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
