Very disappointed
electrical, rise, box not facing/fairing the right way. killed battery when you did the sweep.
move the box around upgrade you electrical and burp higher. sweeps arent always 100% on the dot for your peak either, gotta remember as it sweeps through it will suck power so by the time its saying your peaking you could have lost a few volts.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thats why you don't sweep full tilt.
SMD Super Seller
My Feedback Thread
yeah i know but it will still suck power specaily if he doesnt have electrical upgrades.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
^ he hasnt giving any info on electrical or if he did the sweep full tilt. he could have been playing the system the day before and on the way to be metered aswell. and i said he could have lost a few volts meaning depending on the how/what he did and the electrical system on the car he could have lost as much as a few volts. never siad he will lose a few just from a sweep.
just simply saying that depending on electrical, if he charged the batt(s), or if he swept at full tilt. could have even been a combination of everything.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
From my understanding at all that I've read on the forum, If you're chasing numbers than you have to know the resonant frequency of your car and iirc the only way to come up with that is running a sweep on the termlab with a sealed box and whatever Hz you peak at is your cars resonant frequency, then tune your box a few Hz lower or higher than your resonant frequency (I'm not 100% sure if your supposed to tune lower or higher) and if your looking to seal off from the trunk push the box as far back into the trunk as possible then seal it off, most trunk cars doing big numbers keep the box pushed back as far as possible.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Ok when I did my sweep I didn't do full tilt and I only did the sweep the first try. Then I left the lane to let my car charge for a couple minutes and came back and burped at 40 41 and 42 htz. My elec is stock alt and 2 group 31 batts in the trunk. I new to replace my front battery to a Agm. Not sure what other info you guys need
any pic of the setup? Box specification would help also...
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
  • Who's Online   0 Members, 0 Anonymous, 3892 Guests (See full list)
