DC Sound Lab
In most cases I would say back presssure i.e. in my spl boxes at 2800 watts I fold cones like a champ hence the reason I glass the cones so I can take advantage of the 7k+ the box is capable of generating.
In this instance (I could be wrong) the box appears to be to big causing over excursion and stressing the cone until it gives out. The dustcap is a good indicator of this as well as the stress marks(creases) on the cone.
If your feeling adventerous you could glass matt the cone and glue surround back to it and of course gorilla tape the surround. My best advice would be to recone the sub then adjust the ssf up some to limit power to the sub as its fairly clear to me that its at its mechanical limits in that box.
my responses all came from things rob has taught me over the past year
He said 412 CVX designed the box. 412 CVX is pretty good about designing to specs of the woofer. Unless OP altered specs or asked for bigger box? I firmly believe it should be within range.
Edited by Ballen194
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
I don't remember much about this one, since it was done a while ago, but i'm pretty sure i didn't do more than 1.75 cubes net. In fact i'm pretty sure that it was between 1.5-1.75 cubes net.
I could see the sub folding from back pressure, but I don't see how a puncture wound would show up in just that one spot. i'd imagine the cone of a subwoofer is pretty uniform in strength all the way around.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I can't remember what coil he has on the sub, but with the 3.5k on 1 level 5 12, i would want to be around 1.25 net. I know .25-.5 doesn't sound like alot, but in this case it really is.
I remember rob would have issues moving his baffle just a inch forward..so I think its enclosure...5s are picky but once you get the box right are loud as fawk..go on the small side of enclosure and turn subsonic up like rob said..and I wouldn't play below your tuning
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
did you break it in at all? if not then that can happen to cones when the suspension is too stiff and it causes the cone to fold like that...that or over excursion and unloading
NoFearX18 said:
For 3-4 days. Just had the gain barely turned up
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Haven't even messed with it's been raining and I've been working on my Honda.
which Im pretty sure it ain't a rat or anything because my car has been in the garage on jack stands for 2+ months, and I have never seen a rat or any signs of em since I've lived there
Edited by vettedude102
2003 corvette z06
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
