dc audio torago 20kw 4 x dc level 6 18's early scores up!
hi, this is my current project, its a 1994 toyota torago
gear so far : 4 dc 5k
: 4 x 18"LVL6
: 300 amp alt (exessive amperage)
: gladen sql dual midbass 8 sets (16 mids and 8 tweets)
: 2 mosconi 4 channels
: 6to8 processor
: heaps of shok cable
: 4 bulk pack dynamat
gear to get : blaupunkt new york h/u
: 12 fullriver hc110
ok so final box design is still up in the air so what i am doing for the moment is making a nice solid foundation to work from, only just started but will update when there is more to show... onto to some pics of the gear and car
front stage
cable
subs
amps
some of the build so far
ive got more pics of the same so i wont bore you with them lol.
a question for anybody running this gear over there, will the amps handle .5ohm (as long as power supply is ok) and are the subs happy with 4.5-5cubes?
cheers and any comments are welcome!
TEAM DC AUSTRALIA
hole lot of power for XLs
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
prolly wanna keep the subs in the 5.5 to 6 range and i have heard of the 5.0K handling .5ohms just be careful. if you can try and keep them at 1 ohm and run the heck out of them.
2001 Toyota Avalon (stock other than system)2009 Mitsubishi Lancer GTS (Cat-back custom Exhaust w/ Magnaflow muffler, ECU Flash)1966 Chevelle SS (402BBC, Built TH350 w/2500 stall, Flowmaster exhaust, Coy 5 Spoke Rims, Holley Carb, Elderbrock Intake, Comp Cams Valve Train)Current in Avalon:Kenwood DNX5180 HUJBL 6.5" in front doorsJBL 3/4" tweets in dashJBL 3.5" rear doorsJBL 200w 4ch amp
RE Audio SEX 12D4 Subs (12")
Hifonics Brutus BRZ1200.1D
NVX 4 gauge wiring
NVX Deadner
XS Power D925
Big 3 1/0 ga Q Power wire
Custom box by Pro Audio Gulfport, MS
137.5 SB2 USACIhttp://www.stevemead...on-xls-build-up
cheers guys, yeah im just contemplating some ideas at this stage so ill just keep plugging away for the time being and make a final decision in the next couple of weeks!
good to hear about the amp it looks like ill be probably running at .7 just depends on how much box volume i can get
TEAM DC AUSTRALIA
There is so much money in those high amps,,,,,beautiful
Team Big Un,Team DB Drive, Team DB Driven, Team Xs Power
Team Ohio Gen, Usaci 2-4 modified champ 5 years in a row
Looks to be an interesting build here ... I'm tuned in
I would not recommend running below 1 ohm per amp on the Xls. You have a shit ton more power than you need for the XL platform. If you want to use the 5ks to their full potential, then i would recommend stepping up and getting the Level 5s. 3500w of clamped clean power is about the most you are going to be able to put to the XLs in a daily application, anymore than that will just start to get burnt off as heat and could pottentially cause you problems.
  • Who's Online   2 Members, 0 Anonymous, 1856 Guests (See full list)
