Stopping my back hatch from moving?
So I have an issue where the back hatch on my car moves a ton (27hz and below) and pretty much kills my lows.
It's not that it's flexing, its that it is pivoting on the hinge and moving across the latch. Similar to the motion of opening and closing it.
Any ideas on the most effective way to reduce this?
What's on my mind: sound deadening will certainly make it more rigid, but is it the most effective way to hold the panel in place? How about mass loading to make it heavier / greater inertia so it will move less?
From a quick visual inspection, I don't see a way to adjust it.
The vehicle in question is a 2003 subaru forester (wagon / crossover SUV).
I went onto Chilton and didn't see anything and I don't see any place I trust to get the service manual from.
http://techinfo.subaru.com/search/index.html
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Good luck. The only real thing I've been told that will help is to run all thread from the hatch to the floor and use a tensioner in the middle to tighten down. But that's not practical for daily use. You have no idea how bad a hatch can actually flex
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
use great stuff spray foam inside the hatch lid/door. it will add weight to it and can make a big difference. did it to mine and it helped. just make sure anywires in there dont get caught up in the foam or else you will have a fun time digging the wires out if you ever need to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • 4 weeks later...
like alaskanzx5 said i would deffinitly say great stuff foam would help and some sound deadner that is about all i can think of the great stuff foam should help some to add weight to the hatch but for daily driving wouldnt want to put all thread on it or anything like that. Just am idea but maby a latch on each side of the hatch inside to tight'n the hatch in a way would definitly have to modified as for to be able to tight'n it and los'n it and also be able to be removed as to be able to open that hatch when ever you wanti am hopping this helps
  • 4 weeks later...
im having the same problem with my hatch and i think im going to try the threaded rod idea. thanks for the info. i'll keep you posted on how well it works
i'm new to the spl world and loving it!!!
4- power acoustik mofo 152s
rd d9
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
