ChevyBoy95 Posted July 23, 2014 Author Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kyblack76 Posted July 23, 2014 Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. There is a lot of torque applied at start, and then at PULL. Mine hobbled a BIT with nothing on the rear. COuld you send me that ? Like trace it, and the holes on a paper, or if you had it cut by a pro please? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Swordlordboy1234 Posted July 23, 2014 Report Posted July 23, 2014 Heatwave bound? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
ChevyBoy95 Posted July 23, 2014 Author Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. There is a lot of torque applied at start, and then at PULL. Mine hobbled a BIT with nothing on the rear. COuld you send me that ? Like trace it, and the holes on a paper, or if you had it cut by a pro please? I could send you the .25" MDF template I made. Had it cut out by a buddy using a plasma cutter, then grinded the edges smooth (the 3/8" steel final). The way I shaped it, it will fit a large case on the left, and a small case on the right (left side has a 6.25" diameter, left is like 5.5"). So If you want 2 large cases, the right side will have to be cut out a bit wider. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kyblack76 Posted July 23, 2014 Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. There is a lot of torque applied at start, and then at PULL. Mine hobbled a BIT with nothing on the rear. COuld you send me that ? Like trace it, and the holes on a paper, or if you had it cut by a pro please? I could send you the .25" MDF template I made. Had it cut out by a buddy using a plasma cutter, then grinded the edges smooth. Got one..... I have access to a flo jet also.... If you could even draw the DIMS and take a PIC, that would work fine bro. Nice work dude. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ChevyBoy95 Posted July 23, 2014 Author Report Posted July 23, 2014 Heatwave bound? yeeessss Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted July 23, 2014 Author Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. There is a lot of torque applied at start, and then at PULL. Mine hobbled a BIT with nothing on the rear. COuld you send me that ? Like trace it, and the holes on a paper, or if you had it cut by a pro please? I could send you the .25" MDF template I made. Had it cut out by a buddy using a plasma cutter, then grinded the edges smooth. Got one..... I have access to a flo jet also.... If you could even draw the DIMS and take a PIC, that would work fine bro. Nice work dude. OK. But if you want the template, I have no use anymore, if i need to make another one for any reason, i have my 3/8" steel bracket. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kyblack76 Posted July 23, 2014 Report Posted July 23, 2014 One thing. What kind of bolts are those holding it in? Like what grade when the truck starts it will torque on them so youll want something hihhngrade pretty sure they are stainless steel, but ill have to double check. That was just the test fitting. There is a lot of torque applied at start, and then at PULL. Mine hobbled a BIT with nothing on the rear. COuld you send me that ? Like trace it, and the holes on a paper, or if you had it cut by a pro please? I could send you the .25" MDF template I made. Had it cut out by a buddy using a plasma cutter, then grinded the edges smooth. Got one..... I have access to a flo jet also.... If you could even draw the DIMS and take a PIC, that would work fine bro. Nice work dude. OK. But if you want the template, I have no use anymore, if i need to make another one for any reason, i have my 3/8" steel bracket. hmmmmmmmmm SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
boom50cal Posted July 24, 2014 Report Posted July 24, 2014 Kyle you really don't need another alt yet, you haven't even got bored of the second new one but fuck it. THIS IS AUDIO OVERKILL IS AWESOME On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Kyblack76 Posted July 24, 2014 Report Posted July 24, 2014 Kyle you really don't need another alt yet, you haven't even got bored of the second new one but fuck it. THIS IS AUDIO OVERKILL IS AWESOME 2 more are already being built man.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
