2 smaller amp or 1 big amp?
budah93
I have 2 sa15s in a 98 jimmy. big 3 upgrade 2 batteries electrical system is great. i'm about to do a new amp set up for the subs. I have 2 options that i can get at a very very good price. Should I do 2 kicke zx 1000.1's or should I do 1 Sundown SAZ2500d? I do know they are be over powered but everything will be clean power with out clipping
keep it simple, 1 amp= less headaches. you dont hvae to gain match and what not
Sundown FTW ! I need the same saz 2500 for my btl !
But Kicker amps are very good ones too. Like they said, it will be much easier to run a single amp.
If I understand correctly you would use each Kicker at 2 Ohms and the Sundown at 1 ? I hope so.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
I have recently changed from 2 amps too 1... also i had 2 kicker zx1000.1 and went to a single aq2200. It was too difficult to gain match for the fact that the kickers gain does not increase in small increments. You adjust the gain and it was a big difference. I tuned both kickers with dd-1 and looked at voltage with a dmm and seen that one amp was at 48 ac volts and the other was at 52 ac volts. So when i took it down a notch on the one thats was 52 it dropped it to 46. I was never going to really get an exact match on the volts with a dmm. I however did use the bass boost to accommodate the ac volts and go them near spot on but i wasn't sure using bass boost was the right way to do it so i ened up selling them and buying a single amp.
  • Who's Online   0 Members, 0 Anonymous, 1007 Guests (See full list)
