Zero Gauge Question?
Hey guys I am wondering do you need a sleeve or something at all for your zero gauge in the engine compartment. for example doing the big 3 and your zero gauge gets pretty close to the engine. do you need anything for heat protection or should it be fine? let me know thank guys.
:slayer:
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
Only if it is somewhere where it get's incredibely hot. For the most part, based on the brand, they can take well over 100.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
If it's going to run near a heat source you may want to use some heat insulated shielding (depending on how hot the source) Here is a pic of what I used. I'm sure there are multiple options but I picked this up at the loca autoparts store in the performance section. Heat shielding for starter wire.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I've NEVER run shielding on any of my wire, but have always had a full size pickup. I've always been able to keep my wire from heat and also from rubbing. I've had power and grounds run for years that never wiggled, burned, or rubbed. Take your time planning your routing and you don't have to shield. The insulation is on the wire for a reason.
When I was running wire in my engine bay I just used some spit loom, and wrapped some good quality electrical tape. I ran 4 gauge wire, which I wrapped in 3/8 in split loom, which fit perfect, and then wrapped in in 3M tape. I was also very picky about where I ran my wire, kept it away from anything with excessive heat.
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
My buddy ran his too close to the exhaust manifold and only bad things can happen.
All I can say is DAMN that sucks.
Yep, be safe... for sure,.........
I have gotten away with running my P & G right by my e-manifold for some time. The wire i use from alty to bat (both 1/0 power and ground) is from Ce Autos "kit"...and has a mother outter skin on in,,...... and is great for running down the undercarrige of the car.
Then, with my ocd, i added a lil more, and well,.. i like the color..... so,.. what can i say......SPLIT loom as well...
Power lead in blue, ... past the manifold....to the red on the SINGER.... there is a ground as well, that is to mount.....(not sure if you can see that?) that is made with the same skin as the power, and i also tossed on a black split loom ..
  • Who's Online   1 Member, 0 Anonymous, 1580 Guests (See full list)
