bolts on box instead of screws
KiKaZz74
Ok so I'm going to get a 2nd pIece of mdf to add a 2nd baffle to my box
Question is what bolts/nuts do I get since Im replacing the screws with bolts. I'm going bolts/nuts since I've somehow managed to strip and snap 4 of the 8 deck screws holding my Fi BL 18 to my box.
Any pics/info of what I need and how to do It is appreciated.
Cody C.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Screws break when the baffle flexes. Stop the baffle from flexing.
Unless they're mounted vertically and the screws can't handle the weight....In which case you should get botls lol
I think they are deck screws. They are 1.25" square drives meant for composite decking. But the sub is mounted at a angle behind my passenger seat. But I'm guessing I'd use hex head bolts? Like 2.5"? And like 3/16" thick? And how about liners in the wood?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
What should I use then. I can only get bolts out from the ffront box
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
^^^Agree w/ tacomaguy...been there done that
For my new box, I bought threaded inserts from Mcmaster Carr.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
t-nuts are meh....you'll like them until one comes loose on the back of the baffle and you can't get the bolt out.
ive thought about this before and if you had a really thick baffle you think you could just fiberglass the t-nut to the back of the baffle and just not have the bolt come through all the way?
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
