Cleaning Engine, and underhood?
well my truck's got about 200k miles on it.. my engine and everything under there isint too fancy its just a straight 6, ford power.
just wondering how i should go about degreasing it and cleaning it all up,, they're is oil and stuff under it and what not just wondering what yall recommend.. thanks
also ive noticed my radiator is leaking from the top, where the top hose goes.. should i just replace the radiator or try to fix it by putting radiator leak fixer or whatever in it? ive heard it can mess up the internals in the motor if i did go that route, but i dunno. thanks
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
dont put any of that shit in their big problems come after no joke so just see where its leaking and fix it
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
i replaced the hose and the hose clamp already, its the radiator. but thanks i wont be putting that in they're for sure now haha
  • 2 months later...
check this out
http://www.detailedi...ide/Engine-Bay/
lots of good information
thank you for that.... I stoledid it!!! yippee!!!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
1st, don't put that stop leak garbage in your vehicle, repair it correctly, probably a cracked hose.
2nd, don't detail under your hood, you can, and most likely will do more damage then good. how often do you really look under you hood anyways?
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
don't use any of those sealers ..i heard some actually do work but i think it depends on the situation...i guess if its a minor leak it will work...but i wouldn't risk it
really unless you have a show car it probobly isnt worth detailing under the hood. i would degrease the engine only if it has excessive oil and grime on it. or if you are checking for leaks
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
