I got a #4 unibit to install single 1/0 grommets. Makes it so much more simple and faster.
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
If use holesaw make sure bimetal.and use little bit cutting fluid..and go slow for you dont burn teeth off.
I prefer carbide tip ones.with injector spring.can be ran i higher speeds but cost more money.
so much for that idea
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Thats why you use a step bit/uni bit. I wouldn't suggest it if they didn't make them big enough.
sounds good, i'll have to make a trip to tru value tomorrow.....fuck lowes, everyone there is soooooooo stupiiiiiiddddddd
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Jeezus that looks like a wood hole saw u used. Lol Uhm Uni-Bit is best choice. Even if they don't make 1 big enough u can do 2 side by side. Clean it up with a hand file and affix grommet. Good luck. Also the Uni-bit is expensive, but worth it.
Hole saw works great, You have to get the metal ones and don't buy el-cheapo. I used a large hole saw on both my cut-through and a hole in my firewall for power wire. No issues at all, ate through it like it was butter.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
And is this power wire the size of the wire on telephone poles? DAYUMN that's some gaping right there! Don't tell me Adam got to you...
Sheena = pedobear
That's to get the corner started so he can start do the str8 lines
ended up getting and using a diamond tip cutting wheel for my dremel, decided it'd be easier to make a square since i could barely fit my drill in the area i needed to.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
