TylerParrish Posted September 25, 2012 Report Posted September 25, 2012 Can any sub be used in an infinite baffle? I mean theoretically, i guess yes would be the answer, but should a sub not made for an infinite baffle me used in one? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
will77530 Posted September 25, 2012 Report Posted September 25, 2012 if you lower the power sent to it substantially
TylerParrish Posted September 25, 2012 Author Report Posted September 25, 2012 if you lower the power sent to it substantially If it's still got the correct amount of airspace, why would i have to? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
REVOofRustler Posted September 25, 2012 Report Posted September 25, 2012 I think the idea behind an infinite baffle is that there is no enclosure, so air space really shouldn't come into play. An ideal infinite baffle would be a sub dropped into a huge, endless baffle (infinite baffle) in a completely open space. As far as I understand, the logic behind this is that the front and back waves made by the sub never meet, so there is no cancellation. Infinite baffle subs are made to cope with not having any "back pressure" created by an enclosure without bottoming out. Hope this helps! 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
ChevyBoy95 Posted September 25, 2012 Report Posted September 25, 2012 fi ib3 is a sub meant for infinite baffle Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Joe X Posted September 25, 2012 Report Posted September 25, 2012 Can any sub be used in an infinite baffle? I mean theoretically, i guess yes would be the answer, but should a sub not made for an infinite baffle me used in one? It will work as long as the driver don't go over Xmax, you can help prevent that using the amp subsonic filter. A driver with a big Xmax will be harder to bottom out.
RooTxBeeR Posted September 25, 2012 Report Posted September 25, 2012 I want 4 IB3 18's in my house! On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
TylerParrish Posted September 25, 2012 Author Report Posted September 25, 2012 So then I'm guessing not every sub can be used in an infinite baffle if they aren't meant to cope not having that back pressure? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
conceptM Posted September 26, 2012 Report Posted September 26, 2012 They won't be as ideal no, but free air won't deliver high numbers anyway. It works, just surf youtube looking for woofers being burnt in free air. I guess you'll lose some control as you need to down the power (in some cases a lot). Woofer: 12" Phase Linear Aliante Limited Mids & highs: DLS Ultimate 5 1/4" Amp: Audison VRX 6.420 HU: Sony CDX-C90R
