Really frustrating termlab problem!!
I purchased a used a/c model termlab.
I boot into an XP VM under win7 and install instacal, then install the termlab software. As per the instructions, I plug in the termlab box and open the instacal utility. It says the program will detect the termlab data acquisition system, but I didn't receive any sort of pop up menu saying that anything happened. OK...
So I go to start the software and it gives the error The Term-Lab usb key must be attached to the computer before you can run this program (6043-FF37-FE32).
I tried uninstalling and reinstalling and it does the same thing. This is really frustrating and I'm not sure what to do. I have a laptop that is preinstalled with the software and that works, but the thing is a POS and I'd like to get it installed on my good one. I also don't have the $$$ for new software at the moment either
Key code? I have the activation code if that's what you are talking about
prety sure its only good for one device.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
there ya go. the previous owner and the one you have it on now.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
its two. and it should recog your tl box the first time you boot instacal. if not then something is wrong on the usb side :. drivers or hardware. TL does have several chipset issues in regards to usb, but usually only when trying to take measurements. meaning it starts up and detects fine, but wont read once the application is up and running.
call wayne for the fastest response, but since you bought it second hand he might ask you to buy a matainence package.. idk if those are transferable.
try a different usb port.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
It's two.
actually, wayne has the activation count set to 3, just on the incase someone has a software crash they can reinstall and still go. i was told this multiple times by wayne.
Owner of BigAss Ports
he musta changed it.. i just had a crash issue like a month ago and he said it was two.. i said f it and bought a mp... oh well
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 1673 Guests (See full list)
