Enough Power? Opinions Please
Since i've switched focus on the Mustang to performance, i'm considering losing the rear D6500 and the 4 runs of 1/0 that goes with it. I am only running the Sundown 200.4, ~about 800 watts. If I add a second set of components, it will drop the ohms and the amp will be doing ~1200 watts. Is my DC 270XP and XS S1200 (no extra batteries) enough to cover the 800watts? 1200?
I think it will be ok, just like to hear what others have to say.
SMD Super Seller
My Feedback Thread
That should be way more than enough power. I just wouldnt run it for long periods at full tilt with the car off but you will be perfect with running it with the car on. I doubt you will have voltage drop and if you do it will be a small amount. My only recommendation just in case you switch back into car audio or want to upgrade a little down the line would be to keep a single run of positive and negative going from front to back. You already ran it so the weight of 20 some odd feet of cable by having 2 runs going to the back wont help your speed or anything.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
more than enough
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have an idea. why not get a sundown 8' and run it off 2 channels and run the other 2 channels for your front stage?
Because im running two AA 10's in awesome IB setup off the rear channels.
Meh, its CCA anyway, figure i'll pull it and sell it cheap to a member in need.
And I never ever ever play my stereo with the car off.
more than enough
Thanks.
Should have made this a poll.
SMD Super Seller
My Feedback Thread
Over kill guy- your good my man...
Let er rip .. And great luck bro..
For sure, man.
I honestly was just bored and wanted to make a topic. There's gonna be someone that thinks its not enough, I want to hear the reasoning LOL.
SMD Super Seller
My Feedback Thread
I know its not the same model battery you have but i had a s3400 that is the next step up from your front battery and my stock 120 amp alt on my old car and had a amp that did 1400w rms at a 4 ohm bridge and i didnt really have too much voltage drop unless i went full tilt at idle. If i gave it some gas or was driving around it wouldnt really make the lights flicker or drop lower than 13.8 which i dont think is too bad for just an upgraded battery without the big-3 being done at that time. When i took that same setup and threw my mechman 250 amp alt in i had 0 voltage drop and i also did the big-3 on that too. You will be just fine with your setup Ken.
edit: Just something i heard Matt at mechman say about meades alt for his ISF that if you have a smaller pulley on your alternator and you race the engine that you can over spin the alt and burn it out from having it spin too fast. You may want to get a bigger pulley for it but in doing so it will sacrifice your idle output power on the alt.
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
