OldsBoomer Posted October 18, 2012 Report Posted October 18, 2012 Ok guys im getting another vehicle since the S10 is not totaled. So i have two thoughts either a civic hatch or a burban. Both will use Q's. Burban would get a 4 18" 6th behind the cpillar civic will get either a flat wall or 4th with 12's. I want to make a low ground power and i know cone area helps alot with that. I also have 2 gm alts one brand new with an extrenal rectifier and regulator for a 16v setup. My worry is i wouldnt be able to get this alt on the civic. Anyone know if it can fit in there somewhere? Burban will have either a 5500 on 16v or 2 3500's on a 16v and civic would have a 5500 on a 16v setup Suburban Coming Soon
LT.Smoke Posted October 18, 2012 Report Posted October 18, 2012 Personally I would go Burban if you are looking to go big setup... NOT to mention you already have 2 beefed up Alts that fit a GM and they would probably drop in into the burb I like hondas but they dont really like a TON of weight in them but for a big build i would do the Burb... Just my .02 Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Keith77 Posted October 18, 2012 Report Posted October 18, 2012 For what you want to do I would go with the burb.. You have the alts, more room for batts, and can hold the weight like LT said. Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
CDetty Posted October 18, 2012 Report Posted October 18, 2012 Id go with the hatchie for fuel efficiency. 1999 Honda Civic- RIP 2003 Acura RSX Type-S
AI James Posted October 18, 2012 Report Posted October 18, 2012 burban...fuel efficiency is out the window once you add all the weight into it.
LT.Smoke Posted October 18, 2012 Report Posted October 18, 2012 Id go with the hatchie for fuel efficiency. In large audio setups this is NOT a factor at all lol... Large installs usually start at a few hundred pounds and go up in weight Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
sbg Posted October 18, 2012 Report Posted October 18, 2012 do the hatch u dont need to much in a hatch,, my friend has 2 american bass 15s on a m3 amp with a 90 amp h/o alt and big3, xs batt in back.. 0ga and is doing 151 db ... on the TL on dash! shit is sick! 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
LT.Smoke Posted October 18, 2012 Report Posted October 18, 2012 do the hatch u dont need to much in a hatch,, my friend has 2 american bass 15s on a m3 amp with a 90 amp h/o alt and big3, xs batt in back.. 0ga and is doing 151 db ... on the TL on dash! shit is sick! He already has 2 HO alts for a burb... so that would be the more logical choice... He is NOT looking for numbers either he wants a ground pounder so naturally you want something you can shove a bunch of woofers into Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
OldsBoomer Posted October 18, 2012 Author Report Posted October 18, 2012 do the hatch u dont need to much in a hatch,, my friend has 2 american bass 15s on a m3 amp with a 90 amp h/o alt and big3, xs batt in back.. 0ga and is doing 151 db ... on the TL on dash! shit is sick! 90 amp is h/o? Haha My new one maxed out excessive amperages test bench and i think the burban was my first choice just wanting to save some on gas haha. The 4x4 will be nice though. Smoke you new my plans for the S10 and how stupid low and loud i wanted it. You know more of im looking for my goal eventually is 153 around 25hz i dont think the hatch will allow me to do that. Suburban Coming Soon
HatersGonnaHate Posted October 18, 2012 Report Posted October 18, 2012 What year would the Civic hatch be? The only way you'd possibly get the GM alts to fit is to do an entire A/C and power steering delete.... But even then, it's not guaranteed to fit. The stock location and the surrounding area on the older hatches is about 2 inches away from the fender. Little bit of a tight squeeze. Obvious vote is for the Burban. If you're up for a challenge though, wall the Civic My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
