reg93f150 Posted October 25, 2012 Report Posted October 25, 2012 wasent sure to put this but i think this is the right place.. Well, my fuel gauge hasent ever worked since i got the truck.. but no big deal i can mark it on my odometer for 240 miles a tank, not including at idle just sitting they're, and when im close to 240 ill put in 5 or 10 dollars and then i loose track of everything and its a pain in the ass driving around and not knowing when i might run out of gas.. haha. but if my truck stays off for a while, while the truck is completely off and not turned on for a day or so, it will read a quarter of a tank. no matter how much gas i have in their.. so i was wondering do yall think it could be the sending unit? the fuel float just stuck or too much gas got in it over time and its just floating at the bottom? what else do yall think that it could be? thanks. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
poorfish88 Posted October 25, 2012 Report Posted October 25, 2012 Most likely it's the float. Model of car would be helpful.
Skullz Posted October 25, 2012 Report Posted October 25, 2012 Possible the float is stuck or not working. Are there any other electrical problems with the vehicle? 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
reg93f150 Posted October 25, 2012 Author Report Posted October 25, 2012 the truck is a 1993 f150 straight 6 4.9, and no other eletrical problems as far as i know (knock on wood) haha but yeah that's what i was thinkin.. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
79Bronco Posted October 26, 2012 Report Posted October 26, 2012 It all depends on whether or not the gauge is electrical or mechanical. I think your truck has an electrical gauge on it. The best bet is an aftermarket gauge, mechanical if you can. Trust me, I've been there on my 79 ford, it's not worth the PITA to diagnose what's wrong with the factory gauge. Just go aftermarket and never look back. It's not hard to wire up at all. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
reg93f150 Posted October 29, 2012 Author Report Posted October 29, 2012 Alright cool, should I look on 4 wheel parts? Or whete do you think ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
79Bronco Posted October 31, 2012 Report Posted October 31, 2012 Oreilly sells good, reasonably price mechanical fuel gauges Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
Pitbullx Posted October 31, 2012 Report Posted October 31, 2012 more than likely the sending unit gave up the ghost and needs to be replaced Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
SnowDrifter Posted October 31, 2012 Report Posted October 31, 2012 Check for a sticky 'bobber' or whatever the heck they are called? And check for loose / severed wires or connections everywhere? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
photochrisb931 Posted October 31, 2012 Report Posted October 31, 2012 My 1991 f 150 had the same problem with the front tank it was the sending unit. It has the same engine as yours. I would check the wiring and make sure that when you ground the yellow with light blue tracer(i believe are the correct colors) the gauge goes up then the sender is truly bad. you would need to unplug the plug on top of the tank ground it then turn on the truck and watch the gauge to see if it goes up to full. I cant say the electrical ones are not reliable since my rear one has 200k on it and the one I replaced had 179k so good long life. Barstad
