DubNDodge Posted November 5, 2012 Report Posted November 5, 2012 Another thing to look at is that you are starting/stopping a lot making deliveries. Making a stop then accelerating all that weight can make a difference. Takes a lot more energy to move more weight. Once you get going its not an issue. I notice when carrying around a few friends in my car it takes my car forever to get up to speed. Of course none of the weight is noticed until I decelerate or accelerate. My dad has a 2500 diesel, and he took a hunting trip out to Colorado, we live in Ohio He had a double axle trailer with 2 quads on it, and a ton of gear on the trailer and in the truck bed. He was taking 5 other guys out as well. All around 230ish lbs. He said he was going 80 mph all the way there. I called bullshit. He said it takes awhile to get going that fast, but once you get going it takes little energy to keep going. He had around 20 mpg all the way out. When normally it gets 22. So I'm willing to be if you were going on a highway somewhere your mpg wouldn't change much. It's sorta like city vs highway mpg. Your going to get robbed a lot more city than you will highway will all that weight. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Ram1989custom Posted November 5, 2012 Report Posted November 5, 2012 I actually get better gas mileage with my 500 lb system, simply because I don't drive my truck like a bat outta hell anymore lol. 1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire *3 Kinetik 2400s and a Mechman 270A alt in the future*
falcons03079313 Posted November 5, 2012 Author Report Posted November 5, 2012 Another thing to look at is that you are starting/stopping a lot making deliveries. Making a stop then accelerating all that weight can make a difference. Takes a lot more energy to move more weight. Once you get going its not an issue. I notice when carrying around a few friends in my car it takes my car forever to get up to speed. Of course none of the weight is noticed until I decelerate or accelerate. My dad has a 2500 diesel, and he took a hunting trip out to Colorado, we live in Ohio He had a double axle trailer with 2 quads on it, and a ton of gear on the trailer and in the truck bed. He was taking 5 other guys out as well. All around 230ish lbs. He said he was going 80 mph all the way there. I called bullshit. He said it takes awhile to get going that fast, but once you get going it takes little energy to keep going. He had around 20 mpg all the way out. When normally it gets 22. So I'm willing to be if you were going on a highway somewhere your mpg wouldn't change much. It's sorta like city vs highway mpg. Your going to get robbed a lot more city than you will highway will all that weight. Excellent point. I never thought about that. My city must have dropped by like 10 but highway probably stayed around the same. Well no more big systems for me while I still have this job.
Swordlordboy1234 Posted November 5, 2012 Report Posted November 5, 2012 I think the lesson is, yes weight and additional drag on your engine reduce your mpg, but not an unbearable amount. Otherwise kingofpsyclone would not move his truck. Even with his THOUSANDS of lbs of batteries, subs, box, amp racks, amps, wires, rims, the list goes on. I bet it's over 4,000 lbs. his mpg is 8 city. With an excursion tht would most likely get about 12 if it was stock. The drastic mpg losses are most likely do to "Sanford and sons cars" that have shit for springs and when you put 400 lbs of beat in the trunk, suddenly your trunk drags the ground and your front end is like a huge scoop for air. Run this one by you. Have you ever tried to run directly into 40 mph winds (city speed) or 70 mph winds (highway) with a huge jacket on and jeans? It's a lot harder then if you were wearing a bathing suit and a tank top right? Now if your front end is sticking up because your trunk is squatted, you lose all your aerodianamics. Effectively changing your car from something that can reduce wind drag, to making your front end a huge wind scoop. I'd be willing to wager my bottom dollar that this is what's reducing your mpg so bad. Would also explain why when you put better springs your car handledmbettermandmgot closer to normal mpg. Warning, yes more weight and drag on the engine will reduce mpg. But less then 20% difference between loaded and stock, depending on how elaborate your build is. Not the proclaimed 50% or 70% of mpg like stated above. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Lowroll Posted November 5, 2012 Report Posted November 5, 2012 My truck sits level to the ground with a DC lvl 3 15 in it, down firing box with a C&D battery and a DC 1.2k and a Polk 1100.5. Its rated 19/23 and my commute is 80 miles per day and is about half cit half highway. Before my install I consistently got between 21-22 mpg. Now I get between 19-21. However just last month a buddy and I took it to a car show 5.5 hours away and got 23.5 on the way down and 24.5 on the way back. 2 dudes and all our stuff for a weekend and it got better than estimated mileage. It all has to do with driving style Current System: Pioneer 6900 HU Front Stage: (for now) Soundstream tarantula 5.25 in the doors Soundstream tarantula 4x6 in the dash Kenwood 400.4 for mids & highs Bass: 4 Soundstream RW-12's 2 Power Acoustik Stax 4000/1D's single chamber box, 2.65 cubes. Currently under the knife being bagged Rebuilding err'thang
ewilliams5430 Posted November 5, 2012 Report Posted November 5, 2012 It also depends on if you have a h/o alternator, it takes more horsepower to turn than a stock, resulting in wasted hp. I've noticed lower mpg since I put in my new alt.
boom50cal Posted November 5, 2012 Report Posted November 5, 2012 I think the lesson is, yes weight and additional drag on your engine reduce your mpg, but not an unbearable amount. Otherwise kingofpsyclone would not move his truck. Even with his THOUSANDS of lbs of batteries, subs, box, amp racks, amps, wires, rims, the list goes on. I bet it's over 4,000 lbs. his mpg is 8 city. With an excursion tht would most likely get about 12 if it was stock. The drastic mpg losses are most likely do to "Sanford and sons cars" that have shit for springs and when you put 400 lbs of beat in the trunk, suddenly your trunk drags the ground and your front end is like a huge scoop for air. Run this one by you. Have you ever tried to run directly into 40 mph winds (city speed) or 70 mph winds (highway) with a huge jacket on and jeans? It's a lot harder then if you were wearing a bathing suit and a tank top right? Now if your front end is sticking up because your trunk is squatted, you lose all your aerodianamics. Effectively changing your car from something that can reduce wind drag, to making your front end a huge wind scoop. I'd be willing to wager my bottom dollar that this is what's reducing your mpg so bad. Would also explain why when you put better springs your car handledmbettermandmgot closer to normal mpg. Warning, yes more weight and drag on the engine will reduce mpg. But less then 20% difference between loaded and stock, depending on how elaborate your build is. Not the proclaimed 50% or 70% of mpg like stated above. If he actually drove it, he could average 12-15 mpg. Wonder of the old mighty 7.3l Turbo Diesel He wont drive it though, too top heavy and sketchy. Heard him say it on one of his videos. He probably pays twice for diesel for the tow vehicle than what the X could get. My truck decreased a bit, I spend a bit more time sitting in parking lots banging on it, and dashing around town because of it! On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Katt Posted November 5, 2012 Report Posted November 5, 2012 I get better mpg, when I had my wall. Simply the fact, mentioned above. You can't drive fast, or like a retard. And having about 70hp only goes so far! Only think that sucked about the wall, It was hard to get up to speed on the highway, going from 45-65 sucked. Floored or not. Other then that. it was fine. Also had a 2nd alt on it too, even when no load on it, still dragged it down. So, put that on a switch. Now I just took it off and put my power steering back on. For now. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
TigerTony Posted November 5, 2012 Report Posted November 5, 2012 I got around 21/20 mpg with my system in and out its like 18mpg.
ZachG Posted November 10, 2012 Report Posted November 10, 2012 I think the lesson is, yes weight and additional drag on your engine reduce your mpg, but not an unbearable amount. Otherwise kingofpsyclone would not move his truck. Even with his THOUSANDS of lbs of batteries, subs, box, amp racks, amps, wires, rims, the list goes on. I bet it's over 4,000 lbs. his mpg is 8 city. With an excursion tht would most likely get about 12 if it was stock. The drastic mpg losses are most likely do to "Sanford and sons cars" that have shit for springs and when you put 400 lbs of beat in the trunk, suddenly your trunk drags the ground and your front end is like a huge scoop for air. Run this one by you. Have you ever tried to run directly into 40 mph winds (city speed) or 70 mph winds (highway) with a huge jacket on and jeans? It's a lot harder then if you were wearing a bathing suit and a tank top right? Now if your front end is sticking up because your trunk is squatted, you lose all your aerodianamics. Effectively changing your car from something that can reduce wind drag, to making your front end a huge wind scoop. I'd be willing to wager my bottom dollar that this is what's reducing your mpg so bad. Would also explain why when you put better springs your car handledmbettermandmgot closer to normal mpg. Warning, yes more weight and drag on the engine will reduce mpg. But less then 20% difference between loaded and stock, depending on how elaborate your build is. Not the proclaimed 50% or 70% of mpg like stated above. This would make sense in my case, got 300lbs in the trunk of my gtp and the back end is about a inch or more lower than the front and the front sits up and i lost around 4-5 mpg with the install, wondering if i should get some 1" ride height springs for the back or some 1 1/2" lowering springs for the front 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
