littlehitter Posted November 28, 2012 Report Posted November 28, 2012 I've learned a lot by reading posts by the more experienced people on this site for the past few months, and there is still plenty I need to learn, and even more that I want to try. I'm trying to understand how Fs and tuning of the enclosure correspond. I know that the enclosure sets the response curve and peak of the system. How does the Fs factor in to this? For example: If I take my SeX's which have a Fs of 25.1 Hz and put them in an enclosure tuned to lets say 40 Hz what would I be able to play? Would the low Fs just extend the bass response lower than normal? Would the subwoofer be able to safely play down to 25 hz without risking damage? Thanks for any input in advance, I'm just trying to learn as much as possible because since the audio bug bit me I want to learn everything! haha Current System: Clarion CZ702 Stock 5 channel amplifier Infinity Reference 4022i 4" GRS 6.5" Audiopipe 1800.1 2 RE Audio SEX V2's In a 4th order ported though the armrest 2003 130 Amp Toyota Highlander alternator
SnowDrifter Posted November 28, 2012 Report Posted November 28, 2012 I doubt you would be able to play to 25hz in a 40hz tuned box. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Trey_Dog650 Posted November 28, 2012 Report Posted November 28, 2012 I think FS plays more of a role in a t-line box. A normal ported box I think FS plays very, very minute role Edit: and depending on what you are tuned to you can play maybe 5-10 hz below that safely. Anymore and you really increase your chances of failure 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
SnowDrifter Posted November 28, 2012 Report Posted November 28, 2012 I'm tuned to 35 and the lowest I can still play loudly is 27-28hz. 25hz just makes the woofers move a bunch and doesn't do much ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Trey_Dog650 Posted November 28, 2012 Report Posted November 28, 2012 I'm tuned to 35 and the lowest I can still play loudly is 27-28hz. 25hz just makes the woofers move a bunch and doesn't do much Well your not loud unless your play 15 hz and can hear it!!! Lol 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
wmrcs Posted November 30, 2012 Report Posted November 30, 2012 lol. Fs is the resonant frequency of the speaker. I've always tried to tune within 4hz or so of the subs Fs, but you by no means need to. For example, if I had a Skar VVX with an Fs of 21... I wouldn't tune to 25. I'd tune to 30 though. Lub dem lowz. E34 540iT/6
littlehitter Posted December 3, 2012 Author Report Posted December 3, 2012 Thanks for the replies! Like I said that box was just an example, I'm not gonna build it. Just trying to understand the theory behind enclosures. What would cause damage to the sub playing below the tuning frequency? If the Fs is free air resonance wouldn't the enclosure be null at the fs below tuning? Currently I'm tuned to 34hz and have no problem playing down to the low 20's but I'm also running like 1/4 RMS of my subs. Current System: Clarion CZ702 Stock 5 channel amplifier Infinity Reference 4022i 4" GRS 6.5" Audiopipe 1800.1 2 RE Audio SEX V2's In a 4th order ported though the armrest 2003 130 Amp Toyota Highlander alternator
CJ18 Posted December 3, 2012 Report Posted December 3, 2012 A low fs just means that that sub will be able to play those lower frequencies easier than a sub with a higher fs. Just because a sub may have a higher fs, doesn't mean that it can't play into the mid 20s, it just means that it will have to work harder and will require more motor force to do so. Another thing about ts specs that is very deceiving, ts specs are most commonly run using a tool that only puts out a few watts at most. This barely tickles the sub, yet people rely on these specs to build and tune boxes. So much changes when you put full power to a sub. I would be more interested in knowing the fs of a sub with full rates power going to it.
revoracing247 Posted December 3, 2012 Report Posted December 3, 2012 A low fs just means that that sub will be able to play those lower frequencies easier than a sub with a higher fs. Just because a sub may have a higher fs, doesn't mean that it can't play into the mid 20s, it just means that it will have to work harder and will require more motor force to do so. Another thing about ts specs that is very deceiving, ts specs are most commonly run using a tool that only puts out a few watts at most. This barely tickles the sub, yet people rely on these specs to build and tune boxes. So much changes when you put full power to a sub. I would be more interested in knowing the fs of a sub with full rates power going to it. isn't this one of the reasons d'amore came out with the impedance meter? ~ If it was easy, everybody would be doing it ~
Neckbeard Posted December 3, 2012 Report Posted December 3, 2012 Soooo....Say the Fs of the sub is mid 50s, and the box it is in is tuned 30. Will it still slump the lows? Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
