DC Sound Lab
I am clueless with this one. I have never done a clamp test where the AC Voltage was lower than the Amperage.
Since I cant see where the meters are hooked in, I just want to make sure that the DMM went into the positive and negative speaker wires and the clamp went around the positive speaker wire.
The Positive lead of the DMM was connected to a jumper wire that is connected to the positive speaker input into the DC5K
Vice-versa for the Negative lead to the negative speaker wire input.
Pics of the jumper cable I used:
The clamp meter was clamped around the positive speaker wire.
Should I touch the two jumper wire ends together to see if there were any resistance with the jumper cables?
You sure you weren't clipping during the test?
I probably was clipping during the test because I accidentally went to volume 28 instead of my max tuned 27 at one point. Should I redo the test without going over my max volume?
What hz tone was used for the test?
40Hz @0dB (the test tone I used to set my gains with. There was no clipping when I set the gains without a load. Should I connect the oscope to the speaker wires while running the clamp test to see if it's clipping?
I am kind of confused about the jumper wire. I would stick the probes directly into the wire. Is a bit of a pain to get it through the sheath, but that is going to be the most accurate way to do it.
Even in my first clamp run with the bassknob not all the way up, the ac voltage was lower than the ac amperage. And during that run, I didn't go over my max tuned volume.
Buddy is getting close to 7200 out of each of his 5ks, on 18v.. all 16 amps that is LOL
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
these results dont matter anyway because according to tony your doing it all wrong.
:peepwall:
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
:peepwall:
:ninja:
How can I do this properly?
Here is the very first clamp test that I did on my 7.5k.
This test was done in my 2006 Ford F150. I am running 1 Mike Singer 350a alt charging my 5 XS D1400 14v batteries at 16.4v
Voltage started at 16.4v.
Starting impedance is .67ohms
HZ----AMPS----VOLTS----WATTS----OHMS----Voltage Drop
30----mega_shok.gif.9----96.5----7806.85---1.19----15.2v
35----78.2----100.2---7835.64---1.28----15.2v
40----72.2----103.6---7479.92---1.43----14.1v
45----62.2----107.8---6705.16---1.73----14.7v
50----61.5----106.9---6574.35---1.74----14.7v
  • Who's Online   0 Members, 0 Anonymous, 5415 Guests (See full list)
