DC Sound Lab
How does the 10k compare to the 9k on lower voltage (under 14v)?
10k is rated at 12v 9k is rated at 14v
The specs CJ posted said 14v.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
The 10.0kw competition series amplifier is a 10,000 watt mono block. It is built for 12 volt audio systems.
not rated at ut designed for i spoke wrong
Edited by will77530
Where does it say the 10.0k is rated at 12v? Because cj just posted that its rated at 10,000 watts x1 at 1ohm at 14.4v and that's what it sais on dc's websight. And the 9.0k is rated at 9,000 watts x1 at 1ohm at 14.4v
I know what the posted specs say, but it has been proven that all of the DC amps will put out rated power at 12v.
.....sooooo how do they compare at lower voltages?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Why would you wanna run an amplifier like this at low voltage? Although its been done, ea time it just shortens the life just a little by more
I agree with Jeff. Why would you spend the money on a 10k amp and not feed it the current that it wants? That just doesnt make sense. If you are going to run it at 9-11v, just buy a 5k and keep it happy, you will probably see the same amount of power.
If it was made for lower voltage why would we not ask about it?
If it shouldn't be used at lower voltage then why claim it to be a lower voltage amp?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
