look what I got for christmas :D
I gotta 33 gallon craftsman air compressor and router and table for it I have been wanting those two things for a WHILE so I'm glad I got these. Now the only thing I was a little bummed was that it's a fixed base router..Which I know isn't at versatile as a plunge router, but alls I really need it for at the moment is too cut holes for speakers with the jasper jig that I still have to get, can I still at least do that? I've read that it can be done but might be a little more difficult.F398BEE8-AD24-487F-AF7F-7BDA6BE95C43-427-0000000B5A368E49.jpgF39127AE-115E-471F-8B66-EA7A49A1E377-427-0000000B60057010.jpg
Nice !!!
If I understand it right...
Fixed routers can be adjusted up or down using a screw style clamp.
So what that means is you'd have to drill a hole in the baffle. Adjust the router to the depth you need. Stick it in the pilot hole you made and jig it out from there.
If the router is a plunge that means you can just flip a lever on the fly and move up or down as needed without having to stop and mess with a screw.
If you can't adjust the depth. Your kinda screwed. You could mount the router to the table and make holes like in the first step but idk how easy thtd be.
I've always been told plunge is the only way for car audio. But I'm sure you could make something work.
After looking at the pic closer.. idk. If you can find a plunge adapter like someone else said you'd be ok. It looks like that routers only meant to be mounted.. it would be hard that way.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
You can still use it with a jasper jig its just not nearly as easy
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yea I mean I'm not gonna return it regardless if it was absolutely neccesary I'd buy a plunge, but if I can make this work then I'm gonna make it , I still need to learn how to even use the damn things...now is it possible to get a plunge adapter for that model?
I don't think you can get an adapter for it. Its surprising the table came with a fixed base. Most combos come with a plunge. Im not really a fan of trying to use a jasper on the table anyways. Router tables can be a little spooky if you aren't careful
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
nice man!! i need some help making fiberglass door pods!! looks like i know where to go!! haha
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Well I'll have to see what I can do with it then, I might get a plunge eventually like I said but I'm
Gonna do whatever I can with this one
