How do you put sound systems in newer cars???
The inside of a Ford Taurus.... I can't see any way to get an aftermarket head unit in there.
Note: I have no need to do this. I'm just wondering
pretty much there trying to knock us guys out of buying gear but someone will make a whole replacement for it so you can slap one in there
its fully integrated which makes it supper difficult. Only way i see it is to make a new fiberglassed panel and then re wire the ac/heat somehow..idk though. Seems real hard.
i think metra already has one realesed for it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I think companies will actually make adapters with AC Controls already attached and then they just leave a slot for the new deck.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
This is why OEM integration is so big. If you noticed when steve did his ISF he used his factory head unit and Fosgates new unit that does line level conversion and is tuneable by laptop.
+1 on the OEM integration.
For starters, most people who buy new cars don't care for audio.
Second, anyone that does have the cash for new cars will have enough for the "premium" option (which is $1000 or more for some crappy 8" sub and some crappy factory amp)
Only good factory system I know of is the mustang's shaker 1000 which is 2 10's and supposedly sounds pretty good.
I wouldn't really want an expensive car to get rattled apart anyway.
It also depends on how it looks BEHIND the dash bezel.
As far as the pic up top, it looks like a standard single DIN would fit in there but then the controls...are they attached to one unit, or buttons that are separate from it?
Where there is a will, there is a way.
Googled "2012 ford focus"
first few images:
2012-Ford-Taurus-SH0-14.jpg?g2_GALLERYSID=TMP_SESSION_ID_DI_NOISSES_PMT
Police have the right idea :)
Any tablet running windows can have microsoft streets and trips for GPS. android tablet have GPS programs too I'm sure.
Ad in an EQ with line driver and 3.5mm input and bam. problem solved ;)
2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz
guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
