Running active and passive
BassMunky
24 members have voted
  1. 1. Which do you guys run and why?
    • active
      18
    • passive
      6
Active ALC 20 all day. I have run both, for SQ I spend the extra and run active. For loud I am cool with a good quality passive.
What do you mean about ALC 20? the ambiographic control?
ALC 20 was made by Altec Lansing (old school). I always thought it was one of the coolest active crossovers.
What about Active vs Bi-amp on passive crossovers?
Passive sets the crossover points and uses a small portion of the power and doesn't allow separate adjustment of the tweeter and mid range, unless the crossover has bi-amp inputs.
Active allows you to set crossover points and separate adjustments of tweeter and mid range. There is no power loss due to crossovers in an active setup either.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Which will be louder?
ummm nooo was saying if i go active and use all my channel on the sundown and
channel 1 tweeter
2 tweeter
3 mid
4 mid
going passive and using both crossovers
where as channel 1/2 are bridged using mid and tweeter
3/4 bridged mid and tweeter
do you understand now?
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
My dash (mainly used for stage and image) is a 5.25" component set with passive crossovers ... The midrange and tweeter is close enough to each other that you do not have to separately time align for stage and image and is cut off on the low end by the head unit.
My 6.5" midbass drivers are basically fullrange cut off on the low end by the head unit (time aligned separately from the dash component set) ...
All of this is separately EQ'd ... So I guess you could say I run both, then again, if you break it down ... I run passive and fullrange ... kind of confusing, but honnestly, a simple setup
channel 1 tweeter
2 tweeter
3 mid
4 mid
  • Who's Online   1 Member, 0 Anonymous, 1797 Guests (See full list)
