Any way you could point me in the direction of a good tutorial for this? I have always set by ear and it has always worked for me, but I am always willing to try something that works better.
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
rmschartpm5.jpg Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
new woofers can smell even if you give them like 50 watts of clean power. its just the excess glue burning off. totally normal.
i NEVER smelt coil when breaking in my VVXs. My guess is that your clipping, and if your using the amp in your sig, its certainly the guilty party. And I had a bc2k at .5 out of the gate on mine, so power wasnt the issue
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
Thanks RooTxBeer
If its smelling that means you're doing it right
Honestly it was a VERY slight smell. I know what a fully blown coil smells like and this did not smell nearly that strong. I did stop and check the sub and amp after I smelled it and neither were hot, only a little warm, and like I said above it did not get any worse
Front Highs: stock
Back Mids: Stock
Thanks RooTxBeer
Amps will almost always get pretty warm when slamming, subs can too just not as warm as a amp can without having to worry. Once things get hot to the touch is when you need to look into things.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The amp can put out clean power.Sure its not as good as some brands but it does nearly rated and it does it clean. And for $120 shipped I cant complain so far. I bought my kid a ton of christmas presents instead of a better amp.
Edited by 89capricebass
Front Highs: stock
Back Mids: Stock
Much respect bro
And like others have said.....normally if it's immediate it is probably just some excess glue :)
www.TheAutoSkin.com
MaliBOOM v2"2010 Bagged Malibu on 20s"<< click here<<<
Excursion on 42s Build log<<Click here<<<
Instagram-@theAutoSkinRyan @TheAutoSkin
Owner of The Auto Skin
So over the last couple of days I have had this sub playing at low volume to break it in. The highest it has been is 22/35, it can barely be heard outside of the car, even with the windows down. Today I decided to turn it up a little bit to 26/35 and I heard a a rubbing/flapping noise that seemed to be coming from the sub or the box. I immediately shut the sub off via the sub setting on the deck and checked everything out. I pushed on the cone in the middle slightly and it sounded like the coil was rubbing and it is also stiffer than it should be. When I got the woofer it smelled like ca glue so I figured it was a re cone and didnt press on the cone. I think this is what was causing the slight smell. You couldnt hear the rubbing/flapping noise at low volume. I am filling out the contact form on skars website now
Front Highs: stock
Back Mids: Stock
