n8ball2013 Posted January 3, 2013 Report Posted January 3, 2013 try blowing that photo up some you can see what was once there on yours. You may even want to register at oldspower and see what they think. It very well could be a heater thing. aask him if the heat and ac etc all work. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ducat Posted January 3, 2013 Report Posted January 3, 2013 thats not bad for the car its actually kinda nice! the rocker panel is the panel under the door easy fix if you have a welder and some time. id see if the guy would go down to 1700 than it would be a steal
Truconcept Posted January 3, 2013 Author Report Posted January 3, 2013 wow an oldsmobile forum lol thanks n8 this is the 1st forum ive ever joined if the heat or ac dont work, thats ok for the price this would be a sunny day windows down car anyway thanks 4 the help guys i will check it out 4sure thats not bad for the car its actually kinda nice! the rocker panel is the panel under the door easy fix if you have a welder and some time. id see if the guy would go down to 1700 than it would be a steal how much do u think this welding job would cost? this would be a deal breaker for me as i cannot have water coming up there will be many speakers in the doors **actin bad like a kid at six flags**
ducat Posted January 3, 2013 Report Posted January 3, 2013 it probly doesnt leak, there probly just rusty. dont know how much it would cost i do all my body work.
Kyblack76 Posted January 3, 2013 Report Posted January 3, 2013 Im not much help, but, I'd see if you can get snafu to chime in. He has a blown 72, that is scary looking. And epic cool. Even though your packing chev power, he could help, I'd promise that. EDIT Here he is, with a buddy... the whine is bad ass.... dig the hell outta it.... Yes, im a Tony (both of them) nut hugger...... big time... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Tarball Posted January 3, 2013 Report Posted January 3, 2013 If you dont have inspections in your state then no issue but the smog "Air Pump" and factory manifolds that accept the air injection have been deleted. The heater core bypass could be done much better, currently they have the heater bypass wrapped around the fuel intake line - you want to keep heat AWAY from the fuel lines. You want to put a real throttle spring setup on there. replace the heater core those cheap valve covers are going to leak - usualy in the rear, it will dump oil on the headers and smoke like a bitch. may as well check but with these modifications you can bet there is no catalytic converter as well (or gutted). Inspection or not cats are a federal requirement and can be spot checked on the street. no fan shroud is no good. IMO - if you are looking for something to just buy and drive stay away. If you are ready to put some time and money into this ride to finish what someone else started then step up; this could be a fun ride for the right person. If you are paying someone else to do the work it gets kinda iffy. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Truconcept Posted January 3, 2013 Author Report Posted January 3, 2013 If you dont have inspections in your state then no issue but the smog "Air Pump" and factory manifolds that accept the air injection have been deleted. The heater core bypass could be done much better, currently they have the heater bypass wrapped around the fuel intake line - you want to keep heat AWAY from the fuel lines. You want to put a real throttle spring setup on there. replace the heater core those cheap valve covers are going to leak - usualy in the rear, it will dump oil on the headers and smoke like a bitch. may as well check but with these modifications you can bet there is no catalytic converter as well (or gutted). Inspection or not cats are a federal requirement and can be spot checked on the street. no fan shroud is no good. IMO - if you are looking for something to just buy and drive stay away. If you are ready to put some time and money into this ride to finish what someone else started then step up; this could be a fun ride for the right person. If you are paying someone else to do the work it gets kinda iffy. forum gold right here thanks alot thats too many problems not mentioned by the seller with airpump and what not (no deal now) i do not want 2 be leavin oil smoke at the red light and where i live they are echeck crazy **actin bad like a kid at six flags**
snafu Posted January 3, 2013 Report Posted January 3, 2013 Tarball provided excellent input for you. Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner!
Skullz Posted January 3, 2013 Report Posted January 3, 2013 Not too shaby for 2k, but i would try and see how low you can get it for though. It needs all those vacuum lines and hoses cleaned up, shortened and consolidated for a cleaner look. One area you might have a problem with is the T-top gaskets leaking or sealing properly and making noise at highway speeds, other wise it would make a nice summer project car. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
