Swordlordboy1234 Posted January 5, 2013 Report Posted January 5, 2013 I'm new to cold weather, and today it was 32 in Texas where I'm at. Does anyone have proper subwoofer break in advise? I tried to play "win or lose" from one of decafs zips, and normally I slam that low note and it just wasn't there. So I think my sub was stiff..... Any advise? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
bkolfo4 Posted January 5, 2013 Report Posted January 5, 2013 Just play it and it will break in. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
boom50cal Posted January 5, 2013 Report Posted January 5, 2013 The note might not have been there as dominately because your heater blower motor was running, maybe your marker lamps or headlights were on, fog lamps, mirror heaters, seat warmers, etc: dropping the voltage. Kinda doubtful on your setup though. Voltage drop probably isn't much of an issue. Let em warm up a little and it'll be fine. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
SnowDrifter Posted January 5, 2013 Report Posted January 5, 2013 I've never had any issues and I'm pushing full xmech out of my subs lol. But they are at very low volumes for a few minutes until I get out of the neighborhood onto open road, so I'm not sure if that counts. I think you should be fine. Look at all the people shaking ice off their car going full tilt? I haven't heard of any of them having issues. I think at most, your spider pack will be a bit stiffer. No biggie ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted January 5, 2013 Report Posted January 5, 2013 It could also be the air density. Acoustics can be a PITA. Temperature, humidity - it can all make a difference ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
kevgnar Posted January 5, 2013 Report Posted January 5, 2013 Cold air is WAY less dense than warm air, it prob louder sealed when its cold right? On 2/27/2013 at 9:21 AM, Swordlordboy1234 said: Who needs electrical! It's a bc3500... They make power out of hopes and dreams of children 1990 Oldsmobile Cuttlas Cruiser- New build coming soon!!
kevgnar Posted January 5, 2013 Report Posted January 5, 2013 Dbl post! On 2/27/2013 at 9:21 AM, Swordlordboy1234 said: Who needs electrical! It's a bc3500... They make power out of hopes and dreams of children 1990 Oldsmobile Cuttlas Cruiser- New build coming soon!!
SnowDrifter Posted January 5, 2013 Report Posted January 5, 2013 Cold air is WAY less dense than warm air, it prob louder sealed when its cold right? Cold air is more dense. Cold thing shrink - same amount of "stuff" in a smaller space means higher density But then there is also the issue of humidity... Air can't hold as much water when it gets colder either - so that would reduce the density too. Gotta love this stuff lol ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ChevyBoy95 Posted January 5, 2013 Report Posted January 5, 2013 I live in houston, has been mid 30-40s. I just ball full tilt. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Nate Futuristic Posted January 5, 2013 Report Posted January 5, 2013 30s Shouldn't matter to much but I dare anyone to full tilt in sub zero temps like we have in Wisconsin right now... Rubber surrounds turn into brittle clay...... down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
