Cold weather proper sub break in
30s
Shouldn't matter to much but I dare anyone to full tilt in sub zero temps like we have in Wisconsin right now... Rubber surrounds turn into brittle clay......
Challenge accepted!!
But.... It's not cold enough :(
Honestly, bassing is cold is better (to an extent sub zero and teens you need to warm shit up), voltage is higher, stays higher longer, win win.
We will see. It can only be 1 of 2 things..... Either the cold made my subs not as loud to the ear.... Which I guess is wrong unless they were not warm enough..... Or I messed up my re wiring... Since I changed my wires from 12g CCA to 8g OFC.... I don't think I messed up the wires.. But if I warm it up and after 20 mins its still not as good..l I'm gonna have to take out the subs and check my wires and free air my speakers a bit to make sure they work.
My volts were super high... Used to do full tilt 13.4... Yesterday was like 14.2 full tilt. Almost wanted to. Wire to .25 ohms :) Jk
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
ive noticed that while playing with the subs cold they dont seem to have that same punch to them. i realy think its just because the speakers are cold. makes them a bit stifer for a little bit. let them play through a song or 2 just loud enough to move them. the movement will quickly warm them up.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 655 Guests (See full list)
