obsidian audio 18
is it 1000 rms btw the sub is d4
You should have got a D2 lol... Well, If you want a quality amp that puts out at least 600 @ 2ohm, you're going to need to spend a little more than $175.
2 HDC3 18's
AQ2200D
i got a decent deal for it on ebay so i wasnt being picky. i wanted to get a d2 but they sold out the day before i got the cash back in october. and i cant handle the comp 10s anymore
I didn't know you already purchased the amp.
Just make sure to set your gains properly with something like the DD-1 or an O-Scope, and you should be good.
2 HDC3 18's
AQ2200D
noo ive purchased the sub already and i cant afford either of those i just have to go by ear but ill keep it well within levels to be as safe as i can basically this is just a budget set up for now
  • 1 month later...
i just got a on O-scope not too long ago, and i cannot figure out how to use this thing at all ..
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
Here is a suggestion for the box (easy to build version):
Enclosure Specifications:
Fb = 32 Hz
Vb = 5.8 ft^3
External Height = 20 in
External Width = 36 in
External Depth = 21 in
Port Width = 3 5/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 36 x 21
Left & Right Sides =
Side 1 = 19 1/2 x 17 3/4
Side 2 = 20 1/4 x 17 3/4
Front = 31 5/8 x 17 3/4
Back = 36 x 17 3/4
L Port Internal Assembly Parts:
Front to Back = 15 7/8 x 17 3/4
Assembly guide (generic dimensions):
Important notes:
- The port needs 3 5/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
On the amp, any good quality 1k amp will do.
