Tarball Posted January 16, 2013 Report Share Posted January 16, 2013 Do a blow through or a couple 10s behind the seats CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
bass4thetruck Posted January 16, 2013 Author Report Share Posted January 16, 2013 i dont have the money to do a blow through. and i can fit my Orion XTR104 which has a mounting depth of 5" behind my seats. and also my truck is a stick shift so i have no armrest in the middle to but a amp or a big sub. Link to comment Share on other sites More sharing options...
Integra_boomer Posted January 16, 2013 Report Share Posted January 16, 2013 My buddy who is active on here (Maticus) did a pretty badass setup with 2 12" dc audio lvl 3 12s. He didnt have very much foot room but it can be done. It was loud and competition worth as he placed 1st at alot of shows. He had an s10 single cab as well. 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s Link to comment Share on other sites More sharing options...
bass4thetruck Posted January 17, 2013 Author Report Share Posted January 17, 2013 ill shoot him a message thanks Link to comment Share on other sites More sharing options...
bigmescan Posted January 17, 2013 Report Share Posted January 17, 2013 are you set on 12's? heres what im running and an option. i have a f150 sc SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74 Link to comment Share on other sites More sharing options...
bass4thetruck Posted January 17, 2013 Author Report Share Posted January 17, 2013 are you set on 12's? heres what im running and an option. i have a f150 sc the mounting depth of the sa8v2's are to big for behind my seat :/ i just really want competion bass. like some shit that hits crazy hard Link to comment Share on other sites More sharing options...
CleanSierra Posted January 17, 2013 Report Share Posted January 17, 2013 There really isn't much room in that truck. A single 12 is my suggestion and I personally like the idea of the mounted in center design. I'm currently running an isobaric push/pull enclosure in my regular cab. The outer sub is inverted, and comes out into the center section of the truck. I don't suggest at all doing a blowthrough unless you're wanting a SERIOUS project. If you're wanting some bump in your ride, and want to go ported, the 8s that BigMescan posted will do a fantastic job. You can also look into 10s for a ported application. As far as using 12s, I'm curious if you're in the mindset that they hit "lower" or deeper. That's a myth if you believe that. Those little 8s from SA get down and dirty in the low frequencies. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted January 17, 2013 Report Share Posted January 17, 2013 You're not going to get "competition" bass from a regular cab with no mounting depth. Best suggestion is run a single badass 10 inverted in the center section between the seats. As far as a SIZE of sub , you'll need to measure WHAT legroom you're willing to give up. Get a tape measure, put your seat in a position you can still safely and somewhat comfortably drive. Measure what would be TOP depth, bottom depth, width across cab, and height. There is the trim panel thAt steps out in that truck, so take that into consideration. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted January 17, 2013 Report Share Posted January 17, 2013 I've been waiting on mr Justin to tune in. He is the guy to talk to about single cabs.... I wanna hear his ride, I hear good things about it. But if anyone wants to hear 2 12's murder 24hz and then play 50hz that rattles your brain you need my set up with my ZVX's Justin.... Push pull design? Are you in the 90's?! Jk bro... My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
