Swordlordboy1234 Posted January 18, 2013 Report Posted January 18, 2013 X2..... ^ My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
ChevyBoy95 Posted January 18, 2013 Report Posted January 18, 2013 Not to mention if you want to bang out something in the low 30s to mid 20s you will want that sp4. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
8ight Posted January 18, 2013 Report Posted January 18, 2013 Not to mention if you want to bang out something in the low 30s to mid 20s you will want that sp4. This is more or less what I was getting at I'm gonna hate
kirill007 Posted January 18, 2013 Report Posted January 18, 2013 You guys do know that sensitivity is rated at 1khz, even for subwoofers? Four of the eminence woofers should get as loud, but at a higher frequency. They won't give you the lows that car audio subwoofers will give you. You'd be better off with 2 18 BL's, then those pro audio woofers. There is a reason why they make home audio, car audio or mobile audio subwoofers/speakers. Thinking is the root of all problems... You ALWAYS get what you pay for.
8ight Posted January 18, 2013 Report Posted January 18, 2013 Sensitivity and lows generally do not go hand-in-hand. Low fs drivers (read: car audio subs) usually have more moving mass and are therefore less sensitive. I'm gonna hate
ChevyBoy95 Posted January 18, 2013 Report Posted January 18, 2013 Heavy ass coil and a big cone = not sensitive, but the massive magnets and motor force help combat that which is my some massive ground pounding subs can be extremely musical. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Swordlordboy1234 Posted January 18, 2013 Report Posted January 18, 2013 ZVX 12 with a bl of over 40.... Motor force for days My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
quakecitystudio Posted January 18, 2013 Report Posted January 18, 2013 Dayton Audio just released some new subs UM10 and UM12, Ultimax Subwoofers, you can find them at partsexpress just like the Eminence Bass Music Producer • Photographer • Graphic Designer -------------- Deep Sector Boom...
kalilac619 Posted January 18, 2013 Report Posted January 18, 2013 Heavy ass coil and a big cone = not sensitive, but the massive magnets and motor force help combat that which is my some massive ground pounding subs can be extremely musical. actually the SP4 motors arent that strong with a BL^2/Re rating of 144 compared to say the AA mayhems 223 or the FI UFO motors 240...but i agree OP is better off with a REAL subwoofer over a PA woofer.PA woofers have good impact to say about 40hz but roll off fast after that..... 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Tito DeLatorre Posted January 18, 2013 Report Posted January 18, 2013 oh so hes not getting loud, i was under a different impression.
