"How to Install an Amp" Essay
Alright.. so in English class, we need to write a process analysis essay to count as our midterm. The essay can be about anything that we're passionate about. The essay can be either directive or explanatory. I chose directive. The essay I decided on is "How to Install an Amp."
Here's what Im going to mention:
Power Input- Partially completes circuit. Mention wire size & its capacity. Also mention fuse size. Bring up consequences of running too small wire and fuse, along with a fuse too large. Mention voltage.
Ground- Partially completes circuit. Mention wire size & its capacity. Bring up acceptable grounding locations.
Remote Turn On- Tells the amp to turn on
Highpass (Subsonic) Filter- Only higher frequencies than set SSF play. Prevents damage to sub from playing too low frequencies. Mention bottoming out.
Lowpass Filter- Only lower frequencies than LPF play. Prevents damage to sub from playing too high frequencies.
Input/Output RCAs- carries analog signal between HU & amps
Gain- matches amp input voltage with headunit output voltage. Go over RCAs briefly.
Phase- delays the signal being produced by the amp
Speaker Inputs- sends signal to actual speaker. Mention wire size.
Bass Knob- Can only reduce gain to reduce volume.
Can anybody add anything else worth mentioning?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Maybe start off with explaining where to find a good place to mount the amp?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Nice. I didnt even think of that.
Gain: problems when turning it too high. Clipping or distortion.
Proper mounting? A place with good air flow and something sturdy that doesn't allow the amp to slide and bump around.
Ohm load.
:good:
LMFAO so true
:blush:
maybe cover why the addition improves the sound. Also a little history of where aftermarket car audio came from
Thatd make a good introduction.
I don't think high frequencies can damage a sub. The point of the LPF is just that you don't want your sub to play them as they aren't produced well.
Also, the phase doesn't exactly delay the signal. If it did, only one specific frequency would be 180° out of phase.
Have you thought about, or are you going to talk about mids and highs amps and/or mutliple amp setups?
Yeah, but I believe that too high frequencies can damage a driver.
What does it do then?
Im talking about single amp setups. Im most likely going to talk about sub amps. Thatd be most clear probably.
LMFAO so true
:blush:
Speaker Input Output- sends signal to actual speaker. Mention wire size.
:peepwall:
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
